メインコンテンツにスキップ
Dell Inspiron 17" 7786 2-in-1 Wireless Card (NIC) Replacement
必要な工具と部品
  1. Dell Inspiron 17" 7786 2-in-1 Wireless Card (NIC) Replacement, Base Cover: 手順 1、 2の画像 1 Dell Inspiron 17" 7786 2-in-1 Wireless Card (NIC) Replacement, Base Cover: 手順 1、 2の画像 2
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Wireless Card (NIC) Replacement: 手順 2、 2の画像 1 Dell Inspiron 17" 7786 2-in-1 Wireless Card (NIC) Replacement: 手順 2、 2の画像 2
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Wireless Card (NIC) Replacement: 手順 3、 3の画像 1 Dell Inspiron 17" 7786 2-in-1 Wireless Card (NIC) Replacement: 手順 3、 3の画像 2 Dell Inspiron 17" 7786 2-in-1 Wireless Card (NIC) Replacement: 手順 3、 3の画像 3
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Wireless Card (NIC) Replacement: 手順 4、 3の画像 1 Dell Inspiron 17" 7786 2-in-1 Wireless Card (NIC) Replacement: 手順 4、 3の画像 2 Dell Inspiron 17" 7786 2-in-1 Wireless Card (NIC) Replacement: 手順 4、 3の画像 3
    • Carefully remove the base cover from the laptop.
  5. Dell Inspiron 17" 7786 2-in-1 Wireless Card (NIC) Replacement, Wireless Card (NIC): 手順 5、 3の画像 1 Dell Inspiron 17" 7786 2-in-1 Wireless Card (NIC) Replacement, Wireless Card (NIC): 手順 5、 3の画像 2 Dell Inspiron 17" 7786 2-in-1 Wireless Card (NIC) Replacement, Wireless Card (NIC): 手順 5、 3の画像 3
    • Remove the screw holding down the small bracket for the wireless card using a Phillips #0 screwdriver.
    • Remove the black wired connection from the port over the black triangle.
    • Remove the wire with the white marking from the port above the white triangle.
    • Pull the Wi-Fi card out of its slot.
終わりに
作成者
2人の作成者と共同で作成されました。
Antonio Franco
メンバー登録日: 08/25/22
1,025 ポイント
10のガイドは作成済み
チーム
Gateway, Team 1-3, Class Fall 2022 Gateway, Team 1-3, Class Fall 2022人のメンバー
GCC-CLASS-F22S1G3
4 メンバー
15のガイドは作成済み
0 Guide Comments
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 24
今までの合計 643
