はじめに
A power button that also functions as a fingerprint reader for an easier way to log in. A press of this button feels minuscule, soft, and is even quiet. The component itself is really only the fingerprint reading function, as the component that powers on the computer is the I/O board.
必要な工具と部品
Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
Remove the screw holding down the small bracket for the wireless card using a Phillips #0 screwdriver.
Remove the black wired connection from the port over the black triangle.
Remove the wire with the white marking from the port above the white triangle.
Pull the Wi-Fi card out of its slot.
Loosen seven 3 mm captive screws securing the heatsink to the motherboard using a Phillips #0 screwdriver.
この手順で使用する道具:Tweezers$4.99
Locate the ribbon cables for the assembly on the right hand side marked "MB1" and "MB2."
The "MB1" ribbon is locked with a copper/brass colored handle that must be lifted upwards. Then you can remove the ribbon by pulling it away from the socket.
The "MB2" ribbon is locked in its socket with a black latch. Using a non-metallic precision tool (such as tweezers) lift the latch and pull away the MB2 cable.
Lift the latch holding down the ribbon cable on the I/O board, then pull it away using the blue tab.
Lift the I/O board upwards to remove it from the assembly.
Lift the latch holding down the ribbon cable. Remove the cable away from the port.
Remove the screw holding down the button in place using a Phillips #0 screwdriver.
Grabbing the cushioning of the button, lift it upwards from the assembly.
