メインコンテンツにスキップ
Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement
必要な工具と部品
  1. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Base Cover: 手順 1、 2の画像 1 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Base Cover: 手順 1、 2の画像 2
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 2、 2の画像 1 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 2、 2の画像 2
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 3、 3の画像 1 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 3、 3の画像 2 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 3、 3の画像 3
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 4、 3の画像 1 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 4、 3の画像 2 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 4、 3の画像 3
    • Carefully remove the base cover from the laptop.
  5. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Fan: 手順 5、 2の画像 1 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Fan: 手順 5、 2の画像 2
    • Gently remove the I/O cable.
  6. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 6、 2の画像 1 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 6、 2の画像 2
    • Remove the fan cable from the motherboard.
  7. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 7、 1の画像 1
    • Remove two 3 mm screws that secure the fan using a Phillips #0 screwdriver.
  8. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 8、 2の画像 1 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 8、 2の画像 2
    • There is a little piece of tape/sticker on the fan that connects it to the heat sink. Gently remove this.
    • Lift the fan off the palm rest assembly.
  9. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Heatsink: 手順 9、 2の画像 1 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Heatsink: 手順 9、 2の画像 2
    • Loosen seven 3 mm captive screws securing the heatsink to the motherboard using a Phillips #0 screwdriver.
  10. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 10、 3の画像 1 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 10、 3の画像 2 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 10、 3の画像 3
    • Lift the heatsink off the motherboard.
終わりに
作成者
2人の作成者と共同で作成されました。
Delia Padilla
メンバー登録日: 08/23/22
588 ポイント
5のガイドは作成済み
チーム
Gateway, Team 1-3, Class Fall 2022 Gateway, Team 1-3, Class Fall 2022人のメンバー
GCC-CLASS-F22S1G3
4 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 18
今までの合計 123
