メインコンテンツにスキップ
Dell Inspiron 17-7746 Hard Drive Replacement
必要な工具と部品
  1. Dell Inspiron 17-7746 Hard Drive Replacement, Hard Drive: 手順 1、 1の画像 1
    • Disconnect the Laptop from the AC adapter and turn off the Laptop.
  2. Dell Inspiron 17-7746 Hard Drive Replacement: 手順 2、 1の画像 1
    • Place laptop so the bottom faces up.
  3. Dell Inspiron 17-7746 Hard Drive Replacement: 手順 3、 3の画像 1 Dell Inspiron 17-7746 Hard Drive Replacement: 手順 3、 3の画像 2 Dell Inspiron 17-7746 Hard Drive Replacement: 手順 3、 3の画像 3
    • Remove the silver 15mm PH1 screw that holds the plastic cover in place over the battery.
    • Remove the 8mm PH 1 screw that holds the plastic cover in place over the battery.
    • Place the screws accordingly because the length of the screws will matter when you reassemble.
  4. Dell Inspiron 17-7746 Hard Drive Replacement: 手順 4、 1の画像 1
    • Using a metal jimmy, pry up to remove the first half of the cover.
  5. Dell Inspiron 17-7746 Hard Drive Replacement: 手順 5、 1の画像 1
    • Apply pressure using your fingertips on the top of the cover, pushing to the front of the laptop. This will make the plate slide off exposing the hard drive.
  6. Dell Inspiron 17-7746 Hard Drive Replacement: 手順 6、 3の画像 1 Dell Inspiron 17-7746 Hard Drive Replacement: 手順 6、 3の画像 2 Dell Inspiron 17-7746 Hard Drive Replacement: 手順 6、 3の画像 3
    • Remove the three black PH1 6mm screws that anchor the hard drive.
    • This screw hole will be empty because the 15mm silver screw that holds the plastic cover will anchor the hard drive down.
  7. Dell Inspiron 17-7746 Hard Drive Replacement: 手順 7、 1の画像 1
    • Using the Jimmy, pry up the hard drive and lift out using your fingers.
  8. Dell Inspiron 17-7746 Hard Drive Replacement: 手順 8、 1の画像 1
    • Gently wiggle and pull the connector to disconnect the Seta Cable attaching the hard drive to the laptop.
  9. Dell Inspiron 17-7746 Hard Drive Replacement: 手順 9、 3の画像 1 Dell Inspiron 17-7746 Hard Drive Replacement: 手順 9、 3の画像 2 Dell Inspiron 17-7746 Hard Drive Replacement: 手順 9、 3の画像 3
    • Remove the harness around the hard drive by removing four black 4mm PH1 screws located on the side.
  10. Dell Inspiron 17-7746 Hard Drive Replacement: 手順 10、 1の画像 1
    • Remove the hard drive from the harness.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Joshua Plagerman
メンバー登録日: 09/26/18
735 ポイント
4のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 18
今までの合計 1,284
