はじめに
This guide will allow you to replace a defective motherboard for the Dell Inspiron 17-5755. Please ensure that the battery is removed before performing this replacement.
必要な工具と部品
Open the display of the laptop as far as possible, and locate the tabs which secure the keyboard to the laptop.
Use a Phillips #0 screwdriver to unscrew the two 8mm screws which secure the base cover.
Use a Phillips #0 screwdriver to remove the 3mm screw which secures the optical-drive assembly to the computer base
Turn the computer over and using a plastic opening tool, push the optical-drive assembly out of the optical drive bay.
Afterwards, safely pull the optical-drive assembly out of the optical-drive bay.
3 の人々がこのガイドを完成させました。
