メインコンテンツにスキップ
Dell Inspiron 17-5755 Keyboard Replacement
必要な工具と部品
  1. Dell Inspiron 17-5755 Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Make sure the computer has been shut down, and isn't plugged into an outlet before attempting to remove the battery.
  2. Dell Inspiron 17-5755 Keyboard Replacement: 手順 2、 2の画像 1 Dell Inspiron 17-5755 Keyboard Replacement: 手順 2、 2の画像 2
    • Find the battery release latch on the bottom side of the computer.
    • Slide the latch to the left until you hear a "click". This indicates that the battery has been released.
  3. Dell Inspiron 17-5755 Keyboard Replacement: 手順 3、 1の画像 1
    • Safely remove the battery from the laptop.
  4. Dell Inspiron 17-5755 Keyboard Replacement, Keyboard: 手順 4、 2の画像 1 Dell Inspiron 17-5755 Keyboard Replacement, Keyboard: 手順 4、 2の画像 2
    • Open the display of the laptop as far as possible, and locate the tabs which secure the keyboard to the laptop.
  5. Dell Inspiron 17-5755 Keyboard Replacement: 手順 5、 1の画像 1
    • Use a plastic opening tool to gently release the tabs that secure the keyboard to the laptop.
  6. Dell Inspiron 17-5755 Keyboard Replacement: 手順 6、 2の画像 1 Dell Inspiron 17-5755 Keyboard Replacement: 手順 6、 2の画像 2
    • Carefully lift the keyboard from the laptop, being mindful of any attachments that it may have.
  7. Dell Inspiron 17-5755 Keyboard Replacement: 手順 7、 3の画像 1 Dell Inspiron 17-5755 Keyboard Replacement: 手順 7、 3の画像 2 Dell Inspiron 17-5755 Keyboard Replacement: 手順 7、 3の画像 3
    • Lift the zero insertion force (ZIF) tab that secures the keyboard back light ribbon cable
    • Afterwards, carefully detach the backlight cable from the laptop.
  8. Dell Inspiron 17-5755 Keyboard Replacement: 手順 8、 3の画像 1 Dell Inspiron 17-5755 Keyboard Replacement: 手順 8、 3の画像 2 Dell Inspiron 17-5755 Keyboard Replacement: 手順 8、 3の画像 3
    • Gently release the ZIF tab that secures the keyboard ribbon cable to the laptop.
    • Afterwards, carefully slide the cable out of its slot.
  9. Dell Inspiron 17-5755 Keyboard Replacement: 手順 9、 2の画像 1 Dell Inspiron 17-5755 Keyboard Replacement: 手順 9、 2の画像 2
    • Now that the keyboard is detached from the laptop, you may safely remove it.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Gabriel Espinal
メンバー登録日: 02/15/17
215 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S6-G1, Lacy Spring 2017 USF Tampa, Team S6-G1, Lacy Spring 2017人のメンバー
USFT-LACY-S17S6G1
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 16
今までの合計 741
