メインコンテンツにスキップ
Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement
必要な工具と部品
  1. Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Battery: 手順 1、 2の画像 1 Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Battery: 手順 1、 2の画像 2
    この手順で使用する道具:
    Anti-Static Wrist Strap
    $7.95
    購入する
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement: 手順 2、 2の画像 1 Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement: 手順 2、 2の画像 2
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Back Cover: 手順 3、 3の画像 1 Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Back Cover: 手順 3、 3の画像 2 Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Back Cover: 手順 3、 3の画像 3
    • Remove the two 5.5mm screws that secure the base cover to the computer's base.
    • Using the plastic opening tool, carefully pry open the base cover starting from the center.
    • Lift the base cover upwards to remove and set it aside.
  4. Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Optical Drive: 手順 4、 3の画像 1 Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Optical Drive: 手順 4、 3の画像 2 Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Optical Drive: 手順 4、 3の画像 3
    • Remove the 5.5mm screw that secures the optical-drive assembly to the computer base
    • Using your fingertips, slide the optical-drive assembly out of the optical drive bay.
  5. Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement: 手順 5、 3の画像 1 Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement: 手順 5、 3の画像 2 Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement: 手順 5、 3の画像 3
    • This step is only needed if replacing the optical drive.
    • Remove the 2.5mm screw that secures the optical-drive bracket to the optical drive assembly.
    • Remove the optical-drive bracket from the optical-drive assembly.
    • Carefully pull the optical-drive bezel and remove it from the optical drive.
  6. Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Hard Drive: 手順 6、 3の画像 1 Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Hard Drive: 手順 6、 3の画像 2 Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Hard Drive: 手順 6、 3の画像 3
    • Remove the 2.5mm screw that secures the hard-drive assembly to the computer base.
    • Using the pull tab, slide the hard-drive assembly to disconnect it from the system board.
    • Lift the hard-drive assembly off the computer base
  7. Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Wireless Card: 手順 7、 3の画像 1 Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Wireless Card: 手順 7、 3の画像 2 Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Wireless Card: 手順 7、 3の画像 3
    • Disconnect the antenna cables from the wireless card.
    • Push the securing tab to release the wireless card.
    • Slide the wireless card out of the wireless-card slot.
  8. Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Keyboard: 手順 8、 3の画像 1 Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Keyboard: 手順 8、 3の画像 2 Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Keyboard: 手順 8、 3の画像 3
    • Turn the computer over and open the display as far as possible
    • Using a plastic opening tool, release the tabs that secure the keyboard to the palm-rest assembly.
    • Before turning over the keyboard, be careful not to pull the keyboard too far away as it could damage the connected ribbon cables.
  9. Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement: 手順 9、 1の画像 1
    • Carefully turn the keyboard over and place it on the palm rest assembly.
    • Lift the latches and disconnect the keyboard cable and keyboard back-light cable from the system board.
    • Lift the keyboard along with the cables, off the palm-rest assembly and set it aside.
  10. Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Palm Rest: 手順 10、 2の画像 1 Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Palm Rest: 手順 10、 2の画像 2
    • Remove the (5) 5.5mm screws that secure the palm rest to the system board.
    • Close the display and turn the computer over.
    • Remove the (10) 5.5mm screws that secure the palm rest to the computer base.
  11. Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement: 手順 11、 3の画像 1 Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement: 手順 11、 3の画像 2 Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement: 手順 11、 3の画像 3
    • Turn the computer over and open the display as far as possible.
    • Lift the connector latches and disconnect the power-button board cable and the touch-pad cable from the system board.
    • Using a plastic scribe, gently lift and release the tabs on the palm rest around the computer base including the backside.
    • Lift the palm rest away from the display assembly.
  12. Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Optical-Drive Connector Board: 手順 12、 3の画像 1 Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Optical-Drive Connector Board: 手順 12、 3の画像 2 Dell Inspiron 17-5749 Optical-Drive Connector Board Replacement, Optical-Drive Connector Board: 手順 12、 3の画像 3
    • Remove the 2.5mm screw that secures the optical-drive connector board to the computer base.
    • Move wireless card wires covering the board away from the board.
    • Slide the optical-drive connector board away from the computer base.
    • Lift the optical-drive connector board away from the computer base.
終わりに
作成者
3人の作成者と共同で作成されました。
Christopher Tran
メンバー登録日: 02/13/18
1,161 ポイント
12のガイドは作成済み
チーム
Washington State, Team S1-G2, Lobnitz Spring 2018 Washington State, Team S1-G2, Lobnitz Spring 2018人のメンバー
WSU-LOBNITZ-S18S1G2
6 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 11
今までの合計 139
