はじめに
A broken optical drive will prohibit users from reading or loading anything from a disk onto their laptop. This guide will show the steps to replace the optical drive on this device.
必要な工具と部品
Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard.
After prying the tabs up, carefully pull the keyboard out of the laptop.
Remove the four 6 mm PH1 Philips head screws under the keyboard.
Carefully pop off the cover using the plastic opening tools and your hands.
ある他の人がこのガイドを完成しました。
