メインコンテンツにスキップ
Dell Inspiron 17 N7010 BIOS Battery Replacement
必要な工具と部品
  1. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove disc drive: 手順 1、 1の画像 1
    • Remove the single Philips screw securing the disc drive.
    • Pull the disc drive out.
  2. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest screws: 手順 2、 3の画像 1 Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest screws: 手順 2、 3の画像 2 Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest screws: 手順 2、 3の画像 3
    • Remove the 22 M2.5x5 Philips screws securing the palmrest to the base.
    • Remove the seven remaining M2x2.5 screws securing the palmrest to the base.
    • Unscrew the two captive screws securing the RAM/HDD door to the base.
    • This must be done in order to access hidden screws under the hard drive.
    • Under the RAM/HDD door, unscrew the hard drive caddy. Remove the caddy.
    • Remove the three M2.5x5 screws from under where the hard drive was.
  3. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove keyboard: 手順 3、 1の画像 1
    • Pop the four keyboard clips with a plastic spudger. As you do the first one, pry to get under the keyboard with your hand.
    • Remove the keyboard cable from the motherboard connector.
  4. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest: 手順 4、 2の画像 1 Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest: 手順 4、 2の画像 2
    • Remove the palmrest cables from the motherboard connectors.
    • Remove the seven M2.5x5 screws securing the palmrest to the base.
    • Lift the palmrest.
  5. Dell Inspiron 17 N7010 BIOS Battery Replacement, Replace the cell: 手順 5、 1の画像 1
    • Use a plastic spudger to get under the CR2032 cell and pry it out carefully.
終わりに
14 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Joseph Sctbunio
メンバー登録日: 09/23/17
7,416 ポイント
42のガイドは作成済み
7 件のコメント
thanks for your help!!!
E P - 返信
I’m happy that my guide helped you!
Joseph Sctbunio -
Lot of screws, wouldn’t even tried this without these instruction.
Thank you.
d223e
Don Endress - 返信
Thanks for the instructions. Computer starts up great now.
jkleinjans - 返信
doresc sa comand pentru Dell Inspiron 17 N7010 BIOS Baterie. 1 bucata. cum se procedeaza?
Florentin Manolea - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 29
過去 30 日: 104
今までの合計 18,155
