はじめに
This repair guide is specified for the Dell Inspiron 16 7620 laptop. The RAM is an essential part of a laptop, and without it, your computer may not even start. This guide outlines the steps needed to replace a RAM module in the Dell Inspiron 16 7620 laptop. To do this, the back of the laptop must be opened, and parts will be removed and inserted. To ensure safety for yourself and your laptop, use iFixit's anti-static wrist strap to ground yourself.
Before beginning, make sure to power off your laptop completely and disconnect from any external power source.
必要な工具と部品
Using a Phillips #00 screwdriver, fully unscrew all seven 5 mm screws circled in red.
Using the same screwdriver, unscrew the two 5 mm screws circled in orange until the back of the laptop begins to pop off.
Starting near the hinges of the laptop, use a jimmy to work around the laptop, carefully prying the back off.
ある他の人がこのガイドを完成しました。
