メインコンテンツにスキップ
Dell Inspiron 16-7610 Touchpad Replacement
必要な工具と部品
  1. Dell Inspiron 16-7610 Touchpad Replacement, Back Case: 手順 1、 2の画像 1 Dell Inspiron 16-7610 Touchpad Replacement, Back Case: 手順 1、 2の画像 2
    • Flip the device over, so the backside is facing up.
    • Use a Phillips #00 screwdriver to remove seven 4.00 mm screws.
    • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
    • The last two screws should remain in the back case and can't be removed.
  2. Dell Inspiron 16-7610 Touchpad Replacement: 手順 2、 1の画像 1
    • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
    • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
    • Remove the back case from the device.
  3. Dell Inspiron 16-7610 Touchpad Replacement, Battery: 手順 3、 3の画像 1 Dell Inspiron 16-7610 Touchpad Replacement, Battery: 手順 3、 3の画像 2 Dell Inspiron 16-7610 Touchpad Replacement, Battery: 手順 3、 3の画像 3
    • Use a Phillips #00 to remove the five screws securing the battery to the laptop.
    • Pull the bundled cable away from the connector in the same direction as the wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Use both hands to life the battery up and remove it from the laptop.
  4. Dell Inspiron 16-7610 Touchpad Replacement, Touchpad: 手順 4、 2の画像 1 Dell Inspiron 16-7610 Touchpad Replacement, Touchpad: 手順 4、 2の画像 2
    • Push the touchpad up from outside of the palm rest assembly.
    • The ribbon cable ripped off of the touchpad on this device. In most situations, you will need to disconnect the cable from the motherboard prior to removing the touchpad.
終わりに
After installing the new touchpad on the Dell Inspiron, retrace the previous steps to put the Dell Inspiron back together.
作成者
4人の作成者と共同で作成されました。
Jerson Gomez
メンバー登録日: 02/02/23
877 ポイント
3のガイドは作成済み
チーム
Gateway, Team 1-3, Pee Spring 2023 Gateway, Team 1-3, Pee Spring 2023人のメンバー
GCC-PEE-S23S1G3
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 40
今までの合計 651
