メインコンテンツにスキップ
Dell Inspiron 16-7610 Battery Replacement
必要な工具と部品
  1. Dell Inspiron 16-7610 Battery Replacement, Back Case: 手順 1、 2の画像 1 Dell Inspiron 16-7610 Battery Replacement, Back Case: 手順 1、 2の画像 2
    • Flip the device over, so the backside is facing up.
    • Use a Phillips #00 screwdriver to remove four 4.00 mm screws.
    • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
    • The last two screws should remain in the back case and can't be removed.
    • Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity.
  2. Dell Inspiron 16-7610 Battery Replacement: 手順 2、 1の画像 1
    • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
    • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
    • Remove the back case from the device.
  3. Dell Inspiron 16-7610 Battery Replacement, Battery: 手順 3、 3の画像 1 Dell Inspiron 16-7610 Battery Replacement, Battery: 手順 3、 3の画像 2 Dell Inspiron 16-7610 Battery Replacement, Battery: 手順 3、 3の画像 3
    • Use a Phillips #00 to remove the five screws securing the battery to the laptop.
    • Pull the bundled cable away from the connector in the same direction as the wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Use both hands to life the battery up and remove it from the laptop.
終わりに
作成者
7人の作成者と共同で作成されました。
Michael Torres
メンバー登録日: 02/02/23
145 ポイント
2のガイドは作成済み
チーム
Gateway, Team 1-3, Pee Spring 2023 Gateway, Team 1-3, Pee Spring 2023人のメンバー
GCC-PEE-S23S1G3
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 75
今までの合計 1,000
