はじめに
In this guide, we will be showing you how to remove the replace the Battery.
必要な工具と部品
Close the display and turn the computer over.
Slide the battery latches on each end of the battery bay to the unlock position. You will hear a click when the battery is unlocked.
Lift and remove the battery off the computer base to disconnect it from the computer.
Align the tabs on the battery with the slots on the battery bay and snap the battery into place.
もう少しです!
ゴール
ある他の人がこのガイドを完成しました。
