メインコンテンツにスキップ
はじめに
This replacement guide will demonstrate how a user can replace the memory card of a Dell Inspiron 15R 5520 laptop.
パーツ
パーツは指定されていません。
  1. We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip device on its back displaying the battery.
  2. Place a finger on both latches and push outwards. Grab by the lip and pull upwards to remove battery. Grab by the lip and pull upwards to remove battery.
    • Place a finger on both latches and push outwards.
    • Grab by the lip and pull upwards to remove battery.
  3. Locate RAM compartment on device and corresponding screws.
    • Locate RAM compartment on device and corresponding screws.
  4. Take your screwdriver and loosen the three 4mm screws to remove the cover. Take your screwdriver and loosen the three 4mm screws to remove the cover. Take your screwdriver and loosen the three 4mm screws to remove the cover.
    • Take your screwdriver and loosen the three 4mm screws to remove the cover.
  5. Place both thumbs on the latches and push outward. The RAM card will pop up. Place both thumbs on the latches and push outward. The RAM card will pop up. Place both thumbs on the latches and push outward. The RAM card will pop up.
    • Place both thumbs on the latches and push outward. The RAM card will pop up.
  6. Carefully hold RAM card from the sides and pull away.
    • Carefully hold RAM card from the sides and pull away.
  7. Repeats steps 6 and 7 for the second RAM card. Repeats steps 6 and 7 for the second RAM card.
    • Repeats steps 6 and 7 for the second RAM card.
終わりに
4 の人々がこのガイドを完成させました。
Joseph Simplicio
メンバー登録日: 2016年09月15日
608 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 18-1, Blackwell Fall 2016 USF Tampa, Team 18-1, Blackwell Fall 2016人のメンバー
USFT-BLACKWELL-F16S18G1
3 メンバー
5のガイドは作成済み
コメント1件
good but too long procedure
Aguven - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 894
