メインコンテンツにスキップ
Dell Inspiron 1545 Power Button Board Replacement
必要な工具と部品
  1. Dell Inspiron 1545 Power Button Board Replacement, Power Button Board: 手順 1、 1の画像 1
    • Turn the laptop off and disconnect it from all power sources.
    • Turn the laptop over so that the bottom is facing upwards.
  2. Dell Inspiron 1545 Power Button Board Replacement: 手順 2、 1の画像 1
    • Slide the release latch while simultaneously pulling the battery outwards.
  3. Dell Inspiron 1545 Power Button Board Replacement: 手順 3、 1の画像 1
    • Slide the battery completely out of the bay.
  4. Dell Inspiron 1545 Power Button Board Replacement: 手順 4、 1の画像 1
    • Once the battery has been removed, take out the two screws (3mm Phillips #1) beneath it. These screws hold the center control cover in place.
  5. Dell Inspiron 1545 Power Button Board Replacement: 手順 5、 1の画像 1
    • Flip the laptop back over to the front and push the screen open as far as possible.
  6. Dell Inspiron 1545 Power Button Board Replacement: 手順 6、 3の画像 1 Dell Inspiron 1545 Power Button Board Replacement: 手順 6、 3の画像 2 Dell Inspiron 1545 Power Button Board Replacement: 手順 6、 3の画像 3
    • The center control cover is very fragile; be careful when prying it off.
    • Pry the center control cover off of the laptop using a plastic opening tool. On the right side of the cover, there is a small divot to help you start removing the cover.
    • Carefully lift the central control cover away from the laptop.
  7. Dell Inspiron 1545 Power Button Board Replacement: 手順 7、 1の画像 1
    • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
  8. Dell Inspiron 1545 Power Button Board Replacement: 手順 8、 1の画像 1
    • Be careful when pulling the keyboard away from the laptop, you may damage the connector holding it to the motherboard.
    • Using your hands, push the keyboard out and away from the laptop.
  9. Dell Inspiron 1545 Power Button Board Replacement: 手順 9、 2の画像 1 Dell Inspiron 1545 Power Button Board Replacement: 手順 9、 2の画像 2
    • Lift the connector latch to remove the keyboard cable from the motherboard.
    • Lift the keyboard away from the laptop.
  10. Dell Inspiron 1545 Power Button Board Replacement: 手順 10、 1の画像 1
    • Lift the connector latch to remove the power button board from the motherboard.
    • Pull on the blue plastic tab to help prevent causing any damage to the connector.
  11. Dell Inspiron 1545 Power Button Board Replacement: 手順 11、 1の画像 1
    • Pry the power button board out with your finger.
    • Pull the power button board away from the laptop.
終わりに
作成者
1人の作成者と共同作成されました。
Michael Hill
メンバー登録日: 02/28/18
193 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 2,326
