メインコンテンツにスキップ
Dell Inspiron 1545 Keyboard Replacement
必要な工具と部品
  1. Dell Inspiron 1545 Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 Keyboard Replacement: 手順 2、 1の画像 1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 Keyboard Replacement: 手順 3、 1の画像 1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 Keyboard Replacement, Base Cover: 手順 4、 1の画像 1
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
  5. Dell Inspiron 1545 Keyboard Replacement: 手順 5、 2の画像 1 Dell Inspiron 1545 Keyboard Replacement: 手順 5、 2の画像 2
    • Carefully lift the base cover vertically away from the laptop.
  6. Dell Inspiron 1545 Keyboard Replacement, Center Control Cover: 手順 6、 1の画像 1
    • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
  7. Dell Inspiron 1545 Keyboard Replacement: 手順 7、 1の画像 1
    • Flip the laptop over to the front and open the display as far as possible.
  8. Dell Inspiron 1545 Keyboard Replacement: 手順 8、 3の画像 1 Dell Inspiron 1545 Keyboard Replacement: 手順 8、 3の画像 2 Dell Inspiron 1545 Keyboard Replacement: 手順 8、 3の画像 3
    • The Center Control Cover is VERY fragile, be careful when using prying tools.
    • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
    • Carefully lift the Center Control Cover away from the laptop.
  9. Dell Inspiron 1545 Keyboard Replacement, Keyboard: 手順 9、 1の画像 1
    • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
  10. Dell Inspiron 1545 Keyboard Replacement: 手順 10、 1の画像 1
    • Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
    • Do not pull hard on the keyboard while removing it, you may damage the keyboard or the keyboard connector.
  11. Dell Inspiron 1545 Keyboard Replacement: 手順 11、 1の画像 1
    • Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
  12. Dell Inspiron 1545 Keyboard Replacement: 手順 12、 1の画像 1
    • Lift the keyboard up and away from the laptop.
終わりに
15 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Nathan Lemay
メンバー登録日: 04/16/14
3,052 ポイント
15のガイドは作成済み
チーム
Cal Poly, Team 9-14, Regan Spring 2014 Cal Poly, Team 9-14, Regan Spring 2014人のメンバー
CPSU-REGAN-S14S9G14
4 メンバー
15のガイドは作成済み
2 件のコメント
Step 4 and 5 are not needed.
James Thrun - 返信
Steps 4 and 5 are unnecessary for removing the keyboard. Other than that, well done.
lee - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 26
今までの合計 6,863
