はじめに
This guide will be utilized mainly if your CPU has gone bad and your laptop is essentially nonfunctional.
  1. Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Slide the release latch while simultaneously pulling backwards on the battery.
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Slide the battery out of the battery bay.
    • Slide the battery out of the battery bay.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  5. Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The screws are connected to the base cover by a washer anddo not remove from the base cover.
  6. Carefully lift the base cover vertically away from the laptop. Carefully lift the base cover vertically away from the laptop.
    • Carefully lift the base cover vertically away from the laptop.
  7. Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
    • Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
    • These screws are held in place by a washer so you should not be able to completely remove the screws.
  8. Pull up on the Heat Sink unit to remove it.
    • Pull up on the Heat Sink unit to remove it.
  9. Using a flathead screwdriver, rotate the locking mechanism counterclockwise to the unlocked position.
    • Using a flathead screwdriver, rotate the locking mechanism counterclockwise to the unlocked position.
  10. The CPU is very fragile and has thin pins.
    • The CPU is very fragile and has thin pins.
    • Remove the CPU by pulling straight upward and away from the laptop.
まとめ
5 の人々がこのガイドを完成させました。
Nathan Lemay
メンバー登録日: 2014年04月16日
2,584 ポイント
15のガイドは作成済み
チーム
Cal Poly, Team 9-14, Regan Spring 2014 Cal Poly, Team 9-14, Regan Spring 2014人のメンバー
CPSU-REGAN-S14S9G14
4 メンバー
15のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 16
今までの合計 1,464
