メインコンテンツにスキップ
はじめに
Before beginning the Dell Inspiron 1526 keyboard replacement guide, be sure that you have all of the tools listed. Because there are some small delicate steps involved, make sure that you are in an environment free of distractions that is well lit.
パーツ
パーツは指定されていません。
  1. Slide the unlock button to the left to release the battery. Slide the battery away from the laptop to remove. The unlock button is located on the bottom of the laptop.
    • Slide the unlock button to the left to release the battery.
    • Slide the battery away from the laptop to remove.
    • The unlock button is located on the bottom of the laptop.
  2. Loosen the two 3.5mm Phillips #1 screws in the battery bay.
    • Loosen the two 3.5mm Phillips #1 screws in the battery bay.
  3. Flip the laptop over.
    • Flip the laptop over.
    • Lift the control cover by prying the right side of the cover with an iFixit opening tool.
  4. Carefully lift the control cover up and forward to reveal a single ribbon cable.
    • Carefully lift the control cover up and forward to reveal a single ribbon cable.
  5. Use tweezers to squeeze the tabs on the connector and remove the ribbon cable.
    • Use tweezers to squeeze the tabs on the connector and remove the ribbon cable.
  6. Remove the control cover. Remove the control cover.
    • Remove the control cover.
  7. Remove the two 3mm Phillips #1 screws at the top of the keyboard where the control cover was.
    • Remove the two 3mm Phillips #1 screws at the top of the keyboard where the control cover was.
  8. Lift the keyboard gently from the top, but do not remove completely.
    • Lift the keyboard gently from the top, but do not remove completely.
    • Looking under the keyboard, towards the touch-pad in the center, lift up the black tab on the connector with tweezers for the keyboard ribbon cable.
  9. Remove the keyboard. Remove the keyboard.
    • Remove the keyboard.
終わりに
Joshua Busick
メンバー登録日: 2019年09月17日
291 ポイント
2のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 52
