Identify the lock mechanisms holding the battery in place.
Slide each button outward with your fingers to disengage the battery.
Pull the battery off with your hand to separate it from the laptop.
Locate the two 5 mm Phillips #1 screws holding down the keyboard that were underneath the panel.
Remove these screws with a Phillips #1 screwdriver.
With the screws removed pull the keyboard up with your hand.
Locate the two Phillips #1 screws holding the Wireless Local Area Network (WLAN) panel in place.
Remove these two screws with a Phillips #1 screwdriver.
Remove the WLAN panel by pulling it up with your hand.
Disconnect the black and white wires attached to the WLAN card by pulling up on the connectors with your fingers.
During reassembly, the black and white wires reconnect to the WLAN card near the black and white triangles, respectively.
Remove the remaining wires from their protective sleeve by hand.
The wires in the sleeve are only used in other Dell laptop models. During reassembly they do not connect to anything so just place them back into the sleeve.
When disconnecting the camera/microphone cable, pull up by the white plug. Pulling on the cable itself can damage it.
Disconnect the camera/microphone cable by prying it upward with the plastic opener tool.
Separate the camera/microphone cable from the case by pulling it up with your fingers.
Remove the two 10 mm Phillips #1 screws from the bottom of the laptop that attach the lid assembly to the laptop with a Phillips #1 screwdriver.
Remove the two 10 mm Phillips #1 screws from the back of the laptop that also attach the lid assembly to the laptop with a Phillips #1 screwdriver.
There is a risk of dropping the lid or base of the laptop, or damaging cables. Make sure no cables are still attached.
Remove the lid by pulling it up from the base of the laptop with both hands.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
