メインコンテンツにスキップ
Dell Inspiron 1520 Display Assembly Replacement
必要な工具と部品
    • Follow the instructions in Before You Begin.
    • Close the display and turn the computer over.
  1. Dell Inspiron 1520 Display Assembly Replacement, Loosen the Screws: 手順 2、 2の画像 1 Dell Inspiron 1520 Display Assembly Replacement, Loosen the Screws: 手順 2、 2の画像 2
    • Loosen the two captive screws that secure the Mini Card compartment cover, then remove the cover and set it aside.
  2. Dell Inspiron 1520 Display Assembly Replacement, Remove the Screws: 手順 3、 2の画像 1 Dell Inspiron 1520 Display Assembly Replacement, Remove the Screws: 手順 3、 2の画像 2
    • Remove the two M2.5 x 8-mm screws from the bottom of the computer.
  3. Dell Inspiron 1520 Display Assembly Replacement, Remove the Screws: 手順 4、 1の画像 1
    • Remove the two M2.5 x 8-mm screws from the back of the computer.
  4. Dell Inspiron 1520 Display Assembly Replacement, Disconnect the Display Cable: 手順 5、 1の画像 1
    • Loosen the captive grounding screw, then disconnect the display cable from the display cable connector on the system board.
  5. Dell Inspiron 1520 Display Assembly Replacement, Disconnect the Connector: 手順 6、 1の画像 1
    • Disconnect the camera/microphone cable from the camera/microphone cable connector on the system board.
  6. Dell Inspiron 1520 Display Assembly Replacement, Lifting the Display Cable: 手順 7、 2の画像 1 Dell Inspiron 1520 Display Assembly Replacement, Lifting the Display Cable: 手順 7、 2の画像 2
    • Lift the display cable and antenna cables from beneath the tabs on the palm rest.
    • NOTICE: Ensure that the display cable and the antenna cables do not get caught beneath the plastic tabs on the palm rest.
  7. Dell Inspiron 1520 Display Assembly Replacement, Lifting the Display Assembly: 手順 8、 1の画像 1
    • Lift the display assembly out of the computer.
    • Align the display hinges with the holes in the base of the computer, then lower the display into place.
  8. Dell Inspiron 1520 Display Assembly Replacement, Sliding the Antenna Cables: 手順 10、 1の画像 1
    • Slide the antenna cables through the hole in the palm rest and the base of the computer.
    • NOTICE: Ensure that the display cable and antenna cables are properly routed and secured beneath the plastic tabs on the palm rest.
  9. Dell Inspiron 1520 Display Assembly Replacement, Routing the Display Cable: 手順 11、 1の画像 1
    • Route the display cable and antenna cables beneath the plastic tabs on the palm rest.
  10. Dell Inspiron 1520 Display Assembly Replacement, Connecting the Cables: 手順 12、 1の画像 1
    • Connect the camera/microphone cable to the camera/microphone cable connector on the system board.
  11. Dell Inspiron 1520 Display Assembly Replacement, Connect the Display Cable: 手順 13、 1の画像 1
    • Connect the display cable to the display cable connector on the system board.
  12. Dell Inspiron 1520 Display Assembly Replacement, Replace the Screw: 手順 14、 1の画像 1
    • Replace and tighten the captive grounding screw.
  13. Dell Inspiron 1520 Display Assembly Replacement, Replace the Screws: 手順 15、 1の画像 1
    • Replace the two M2.5 x 8-mm screws on the back of the computer.
  14. Dell Inspiron 1520 Display Assembly Replacement, Replace the Screws: 手順 17、 2の画像 1 Dell Inspiron 1520 Display Assembly Replacement, Replace the Screws: 手順 17、 2の画像 2
    • Replace the two M2.5 x 8-mm screws on the bottom of the computer.
    • Replace the Mini Card compartment cover and tighten the screws.
ゴール
作成者
1人の作成者と共同作成されました。
Terrence15
メンバー登録日: 12/18/17
79,555 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
43 メンバー
1,985のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 484
