メインコンテンツにスキップ
Dell Inspiron 1501 Wireless Mini-Card Replacement
必要な工具と部品
  1. Dell Inspiron 1501 Wireless Mini-Card Replacement, Battery: 手順 1、 3の画像 1 Dell Inspiron 1501 Wireless Mini-Card Replacement, Battery: 手順 1、 3の画像 2 Dell Inspiron 1501 Wireless Mini-Card Replacement, Battery: 手順 1、 3の画像 3
    • Place the laptop facedown with the battery facing you.
    • Push the switch above the battery to the right and hold it in that position.
    • Lift the battery using the grip on the top and remove it from its socket.
  2. Dell Inspiron 1501 Wireless Mini-Card Replacement, Hinge Cover: 手順 2、 2の画像 1 Dell Inspiron 1501 Wireless Mini-Card Replacement, Hinge Cover: 手順 2、 2の画像 2
    • Open the laptop all the way, rotating the display so that it is level with the surface that you are working on.
    • Insert the spudger underneath the groove on the right side of the hinge cover.
    • Push up to pry the edge of the hinge cover out.
    • Lift up to release the hinge cover from the laptop, working from right to left.
  3. Dell Inspiron 1501 Wireless Mini-Card Replacement, Keyboard: 手順 3、 3の画像 1 Dell Inspiron 1501 Wireless Mini-Card Replacement, Keyboard: 手順 3、 3の画像 2 Dell Inspiron 1501 Wireless Mini-Card Replacement, Keyboard: 手順 3、 3の画像 3
    • Remove the two 5mm JIS #1 screws from the top of the keyboard.
    • Lift the top of the keyboard up and pull the keyboard away from the laptop.
    • Be sure not to break the ribbon connector that attaches the keyboard to the laptop.
  4. Dell Inspiron 1501 Wireless Mini-Card Replacement: 手順 4、 2の画像 1 Dell Inspiron 1501 Wireless Mini-Card Replacement: 手順 4、 2の画像 2
    • Open the latch holding the ribbon from the top
    • Remove the keyboard from the laptop.
  5. Dell Inspiron 1501 Wireless Mini-Card Replacement, Wireless Mini-Card: 手順 5、 2の画像 1 Dell Inspiron 1501 Wireless Mini-Card Replacement, Wireless Mini-Card: 手順 5、 2の画像 2
    • Remove the two wires from their connections.
    • Pull the metal tabs securing the wireless mini-card to the back of the laptop until the card pops up.
    • Remove the wireless mini-card from the laptop.
終わりに
作成者
1人の作成者と共同作成されました。
Don Dao
メンバー登録日: 03/01/18
361 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G4, Simcock Spring 2018 UMass Dartmouth, Team S2-G4, Simcock Spring 2018人のメンバー
UMASSD-SIMCOCK-S18S2G4
4 メンバー
7のガイドは作成済み
コメント 1 件
I have a computer like this. I have a problem that I have not been able to find a solution too. A few parts that support the screen are broken, and I need to know if I will not be able to replace the CPU in the future should I ever decide to cement these specific parts together.
Let me know if you need any more information!
Peter C.
Peter Chapin - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 22
今までの合計 771
