メインコンテンツにスキップ
Dell Inspiron 1501 Display Replacement
必要な工具と部品
  1. Dell Inspiron 1501 Display Replacement, Battery: 手順 1、 3の画像 1 Dell Inspiron 1501 Display Replacement, Battery: 手順 1、 3の画像 2 Dell Inspiron 1501 Display Replacement, Battery: 手順 1、 3の画像 3
    • Place the laptop facedown with the battery facing you.
    • Push the switch above the battery to the right and hold it in that position.
    • Lift the battery using the grip on the top and remove it from its socket.
  2. Dell Inspiron 1501 Display Replacement, Hinge Cover: 手順 2、 2の画像 1 Dell Inspiron 1501 Display Replacement, Hinge Cover: 手順 2、 2の画像 2
    • Open the laptop all the way, rotating the display so that it is level with the surface that you are working on.
    • Insert the spudger underneath the groove on the right side of the hinge cover.
    • Push up to pry the edge of the hinge cover out.
    • Lift up to release the hinge cover from the laptop, working from right to left.
  3. Dell Inspiron 1501 Display Replacement, Keyboard: 手順 3、 3の画像 1 Dell Inspiron 1501 Display Replacement, Keyboard: 手順 3、 3の画像 2 Dell Inspiron 1501 Display Replacement, Keyboard: 手順 3、 3の画像 3
    • Remove the two 5mm JIS #1 screws from the top of the keyboard.
    • Lift the top of the keyboard up and pull the keyboard away from the laptop.
    • Be sure not to break the ribbon connector that attaches the keyboard to the laptop.
  4. Dell Inspiron 1501 Display Replacement: 手順 4、 2の画像 1 Dell Inspiron 1501 Display Replacement: 手順 4、 2の画像 2
    • Open the latch holding the ribbon from the top
    • Remove the keyboard from the laptop.
  5. Dell Inspiron 1501 Display Replacement, Display: 手順 5、 2の画像 1 Dell Inspiron 1501 Display Replacement, Display: 手順 5、 2の画像 2
    • Close display and flip the laptop upside down.
    • Remove the two 8mm JIS #1 screws on the backplate that hold the display.
  6. Dell Inspiron 1501 Display Replacement: 手順 6、 1の画像 1
    • From the back of the computer, remove the two screw covers.
    • Remove the two 8mm JIS #1 screws.
  7. Dell Inspiron 1501 Display Replacement: 手順 7、 2の画像 1 Dell Inspiron 1501 Display Replacement: 手順 7、 2の画像 2
    • Turn the laptop over and open the display.
    • Remove the two 5mm JIS #1 screws on the display hinge.
  8. Dell Inspiron 1501 Display Replacement: 手順 8、 3の画像 1 Dell Inspiron 1501 Display Replacement: 手順 8、 3の画像 2 Dell Inspiron 1501 Display Replacement: 手順 8、 3の画像 3
    • Disconnect the antenna cables from the Mini-Card.
    • Be careful not to knock the standby switch when disconnecting the cables as it is easily broken.
    • Loosen the JIS #1 screw on the display cable.
    • Pull the pull-tab straight up to disconnect the display cable from the laptop.
  9. Dell Inspiron 1501 Display Replacement: 手順 9、 1の画像 1
    • Remove the display from the rest of the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Luc-Anthony Breneville
メンバー登録日: 03/01/18
183 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team S2-G4, Simcock Spring 2018 UMass Dartmouth, Team S2-G4, Simcock Spring 2018人のメンバー
UMASSD-SIMCOCK-S18S2G4
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 21
今までの合計 929
