はじめに
In this guide, we will be showing you how to remove and replace the Memory Modules.
必要な工具と部品
Turn off the computer.
Disconnect the charging cable from the computer.
Flip the computer upside down.
Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
Align the notch on the NEW memory module with the tab on the memory-module slot.
Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
2 の人々がこのガイドを完成させました。
