メインコンテンツにスキップ
Dell Inspiron 15-7548 Fan Replacement
必要な工具と部品
  1. Dell Inspiron 15-7548 Fan Replacement, Back Panel: 手順 1、 2の画像 1 Dell Inspiron 15-7548 Fan Replacement, Back Panel: 手順 1、 2の画像 2
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548 Fan Replacement: 手順 2、 2の画像 1 Dell Inspiron 15-7548 Fan Replacement: 手順 2、 2の画像 2
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548 Fan Replacement, Battery: 手順 3、 2の画像 1 Dell Inspiron 15-7548 Fan Replacement, Battery: 手順 3、 2の画像 2
    • Disconnect the battery from the motherboard by pulling the black tab attached to the cable.
  4. Dell Inspiron 15-7548 Fan Replacement: 手順 4、 2の画像 1 Dell Inspiron 15-7548 Fan Replacement: 手順 4、 2の画像 2
    • Remove the four 2.5x6mm screws using a Phillips #1 screwdriver.
  5. Dell Inspiron 15-7548 Fan Replacement, Fan: 手順 5、 1の画像 1
    • The two fans are located at the top of the computer.
    • The fan on the left is for the GPU (Graphics processing unit) and the right fan is for the CPU (Central processing unit).
  6. Dell Inspiron 15-7548 Fan Replacement: 手順 6、 3の画像 1 Dell Inspiron 15-7548 Fan Replacement: 手順 6、 3の画像 2 Dell Inspiron 15-7548 Fan Replacement: 手順 6、 3の画像 3
    • To unplug the CPU fan lift the black plastic cutout next to the fan.
    • The connection can be removed by hand or with the plastic spudger.
  7. Dell Inspiron 15-7548 Fan Replacement: 手順 7、 2の画像 1 Dell Inspiron 15-7548 Fan Replacement: 手順 7、 2の画像 2
    • Remove the two 2x3mm screws from the fan using the Phillips #1 screwdriver.
    • The unit may now be removed from the board.
    • The black cord running alongside the fan is for the display. Push it aside if it stops you from removing the fan.
  8. Dell Inspiron 15-7548 Fan Replacement: 手順 8、 3の画像 1 Dell Inspiron 15-7548 Fan Replacement: 手順 8、 3の画像 2 Dell Inspiron 15-7548 Fan Replacement: 手順 8、 3の画像 3
    • Disconnect the unit from the motherboard.
    • It may be easier to disconnect with the spudger tool but it can also be done by hand.
  9. Dell Inspiron 15-7548 Fan Replacement: 手順 9、 2の画像 1 Dell Inspiron 15-7548 Fan Replacement: 手順 9、 2の画像 2
    この手順で使用する道具:
    購入する
    • The black and white wires need to be unplugged and removed from the tabs on the fan.
    • Use a pair of tweezers to unplug the wires.
    • When reconnecting the wires connect the white to the top plug and the black to the bottom.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Christopher Fisher
メンバー登録日: 09/26/18
409 ポイント
4のガイドは作成済み
チーム
University of North Texas, Team S7-G3, Thompson Fall 2018 University of North Texas, Team S7-G3, Thompson Fall 2018人のメンバー
UNT-THOMPSON-F18S7G3
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 33
今までの合計 2,628
