はじめに
This guide will walk you through the process of replacing a dead or damaged battery in your Dell Inspiron 15-7548.
必要な工具と部品
Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
Disconnect the battery from the motherboard by pulling the black tab attached to the cable.
4 の人々がこのガイドを完成させました。
