メインコンテンツにスキップ
Dell Inspiron 15-7547 Speakers Replacement
必要な工具と部品
  1. Dell Inspiron 15-7547 Speakers Replacement, Bottom Cover: 手順 1、 1の画像 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Speakers Replacement: 手順 2、 1の画像 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 Speakers Replacement, Speakers: 手順 3、 3の画像 1 Dell Inspiron 15-7547 Speakers Replacement, Speakers: 手順 3、 3の画像 2 Dell Inspiron 15-7547 Speakers Replacement, Speakers: 手順 3、 3の画像 3
    • Orient the computer so that the hinge for the display facing away from you.
    • Start removing the speaker on the left by pushing the speaker in the direction of the tick mark on the 2 outer pegs, then upwards
    • The tick marks on the two marked pegs should indicate the speaker needs to be pushed towards the center of the front of the chassis.
  4. Dell Inspiron 15-7547 Speakers Replacement: 手順 4、 2の画像 1 Dell Inspiron 15-7547 Speakers Replacement: 手順 4、 2の画像 2
    • Remove the left speaker by pushing the speaker in the direction of the tick mark on the center peg, then upwards
    • The tick mark should indicate towards the middle of the back of the chassis.
  5. Dell Inspiron 15-7547 Speakers Replacement: 手順 5、 2の画像 1 Dell Inspiron 15-7547 Speakers Replacement: 手順 5、 2の画像 2
    • Remove the wire connecting the left speaker to the right speaker.
    • The wire is secured by small notches, be careful not to break these.
  6. Dell Inspiron 15-7547 Speakers Replacement: 手順 6、 2の画像 1 Dell Inspiron 15-7547 Speakers Replacement: 手順 6、 2の画像 2
    • Start removing the right speaker by pushing the speaker in the direction of the tick marks on the 2 pegs closest to the front of the device, and then upwards.
    • These tick marks should indicate towards the middle of the back of the chassis.
  7. Dell Inspiron 15-7547 Speakers Replacement: 手順 7、 1の画像 1
    • Remove the right speaker by pushing in the direction of the tick mark on the final peg, and then upwards.
    • This tick mark should point towards the center of the right side of the chassis.
  8. Dell Inspiron 15-7547 Speakers Replacement: 手順 8、 2の画像 1 Dell Inspiron 15-7547 Speakers Replacement: 手順 8、 2の画像 2
    • Remove the cable connecting the right speaker to the motherboard by pulling towards the front of the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Claro
メンバー登録日: 09/10/18
591 ポイント
5のガイドは作成済み
チーム
Appalachian State University, Team S2-G4, Menagarishvili Fall 2018 Appalachian State University, Team S2-G4, Menagarishvili Fall 2018人のメンバー
APSU-MENAGARISHVILI-F18S2G4
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 15
今までの合計 586
