メインコンテンツにスキップ
Dell Inspiron 15-7547 Keyboard Replacement
必要な工具と部品
  1. Dell Inspiron 15-7547 Keyboard Replacement, Bottom Cover: 手順 1、 1の画像 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Keyboard Replacement: 手順 2、 1の画像 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 Keyboard Replacement, Battery: 手順 3、 2の画像 1 Dell Inspiron 15-7547 Keyboard Replacement, Battery: 手順 3、 2の画像 2
    • Remove the five 5.0 mm-long Philips #0 screws that connect the battery to the case.
  4. Dell Inspiron 15-7547 Keyboard Replacement: 手順 4、 2の画像 1 Dell Inspiron 15-7547 Keyboard Replacement: 手順 4、 2の画像 2
    • Lift the battery out of the case.
  5. Dell Inspiron 15-7547 Keyboard Replacement: 手順 5、 3の画像 1 Dell Inspiron 15-7547 Keyboard Replacement: 手順 5、 3の画像 2 Dell Inspiron 15-7547 Keyboard Replacement: 手順 5、 3の画像 3
    • Pull the battery cable's pull tab towards the battery to disconnect it from the motherboard.
    • Pull parallel to the motherboard, not straight up.
    • Most of the cable is attached to the case with adhesive, which may cause slight resistance.
    • Remove the battery.
  6. Dell Inspiron 15-7547 Keyboard Replacement, Hard Drive: 手順 6、 2の画像 1 Dell Inspiron 15-7547 Keyboard Replacement, Hard Drive: 手順 6、 2の画像 2
    • Remove the four 5.0 mm-long Philips #0 screws connecting the hard drive to the chassis.
  7. Dell Inspiron 15-7547 Keyboard Replacement: 手順 7、 2の画像 1 Dell Inspiron 15-7547 Keyboard Replacement: 手順 7、 2の画像 2
    • Disconnect the hard drive from the motherboard by placing your fingers at the back, and pulling forward towards the front of the chassis.
  8. Dell Inspiron 15-7547 Keyboard Replacement: 手順 8、 1の画像 1
    • Lift the hard drive out of the chassis.
  9. Dell Inspiron 15-7547 Keyboard Replacement, WiFi Card: 手順 9、 2の画像 1 Dell Inspiron 15-7547 Keyboard Replacement, WiFi Card: 手順 9、 2の画像 2
    • Remove the 3.0 mm-long Philips #0 screw at the end of the Wifi-Card
  10. Dell Inspiron 15-7547 Keyboard Replacement: 手順 10、 2の画像 1 Dell Inspiron 15-7547 Keyboard Replacement: 手順 10、 2の画像 2
    • Remove the Wifi-Card from its socket by pulling away and up from the connector.
  11. Dell Inspiron 15-7547 Keyboard Replacement: 手順 11、 2の画像 1 Dell Inspiron 15-7547 Keyboard Replacement: 手順 11、 2の画像 2
    • Disconnect the white and black cables from the Wifi-Card.
    • Make a note of which wire goes where for reconnecting them to the replacement card.
  12. Dell Inspiron 15-7547 Keyboard Replacement, Speakers: 手順 12、 3の画像 1 Dell Inspiron 15-7547 Keyboard Replacement, Speakers: 手順 12、 3の画像 2 Dell Inspiron 15-7547 Keyboard Replacement, Speakers: 手順 12、 3の画像 3
    • Orient the computer so that the hinge for the display facing away from you.
    • Start removing the speaker on the left by pushing the speaker in the direction of the tick mark on the 2 outer pegs, then upwards
    • The tick marks on the two marked pegs should indicate the speaker needs to be pushed towards the center of the front of the chassis.
  13. Dell Inspiron 15-7547 Keyboard Replacement: 手順 13、 2の画像 1 Dell Inspiron 15-7547 Keyboard Replacement: 手順 13、 2の画像 2
    • Remove the left speaker by pushing the speaker in the direction of the tick mark on the center peg, then upwards
    • The tick mark should indicate towards the middle of the back of the chassis.
  14. Dell Inspiron 15-7547 Keyboard Replacement: 手順 14、 2の画像 1 Dell Inspiron 15-7547 Keyboard Replacement: 手順 14、 2の画像 2
    • Remove the wire connecting the left speaker to the right speaker.
    • The wire is secured by small notches, be careful not to break these.
  15. Dell Inspiron 15-7547 Keyboard Replacement: 手順 15、 2の画像 1 Dell Inspiron 15-7547 Keyboard Replacement: 手順 15、 2の画像 2
    • Start removing the right speaker by pushing the speaker in the direction of the tick marks on the 2 pegs closest to the front of the device, and then upwards.
    • These tick marks should indicate towards the middle of the back of the chassis.
  16. Dell Inspiron 15-7547 Keyboard Replacement: 手順 16、 1の画像 1
    • Remove the right speaker by pushing in the direction of the tick mark on the final peg, and then upwards.
    • This tick mark should point towards the center of the right side of the chassis.
  17. Dell Inspiron 15-7547 Keyboard Replacement: 手順 17、 2の画像 1 Dell Inspiron 15-7547 Keyboard Replacement: 手順 17、 2の画像 2
    • Remove the cable connecting the right speaker to the motherboard by pulling towards the front of the device.
  18. Dell Inspiron 15-7547 Keyboard Replacement, CPU Fan: 手順 18、 2の画像 1 Dell Inspiron 15-7547 Keyboard Replacement, CPU Fan: 手順 18、 2の画像 2
    • Remove the two 5.0 mm-long Philips #0 screws from the fan.
    • The screw marked in orange will remain captive to the fan.
  19. Dell Inspiron 15-7547 Keyboard Replacement: 手順 19、 2の画像 1 Dell Inspiron 15-7547 Keyboard Replacement: 手順 19、 2の画像 2
    • Disconnect the wire that connects the fan to the motherboard. This can be found under the flap directly to the left of the fan.
  20. Dell Inspiron 15-7547 Keyboard Replacement: 手順 20、 1の画像 1
    • Lift the fan out of the chassis.
  21. Dell Inspiron 15-7547 Keyboard Replacement, LCD Assembly: 手順 21、 3の画像 1 Dell Inspiron 15-7547 Keyboard Replacement, LCD Assembly: 手順 21、 3の画像 2 Dell Inspiron 15-7547 Keyboard Replacement, LCD Assembly: 手順 21、 3の画像 3
    • Remove the six 7.0 mm-long Philips #0 screws that mount the hinges.
  22. Dell Inspiron 15-7547 Keyboard Replacement: 手順 22、 3の画像 1 Dell Inspiron 15-7547 Keyboard Replacement: 手順 22、 3の画像 2 Dell Inspiron 15-7547 Keyboard Replacement: 手順 22、 3の画像 3
    • Use a spudger to unlatch and unplug the display cable.
    • There will be a notch on the side of the connector.
  23. Dell Inspiron 15-7547 Keyboard Replacement: 手順 23、 3の画像 1 Dell Inspiron 15-7547 Keyboard Replacement: 手順 23、 3の画像 2 Dell Inspiron 15-7547 Keyboard Replacement: 手順 23、 3の画像 3
    • Raise the left and right hinges.
  24. Dell Inspiron 15-7547 Keyboard Replacement: 手順 24、 1の画像 1
    • Remove the LCD display assembly from the laptop.
  25. Dell Inspiron 15-7547 Keyboard Replacement, Motherboard: 手順 25、 3の画像 1 Dell Inspiron 15-7547 Keyboard Replacement, Motherboard: 手順 25、 3の画像 2 Dell Inspiron 15-7547 Keyboard Replacement, Motherboard: 手順 25、 3の画像 3
    • Unlatch the ribbon cable by pulling the white release up.
    • If this proves to be difficult using your fingers, try a plastic spudger.
    • Hold the blue flap and pull to unplug the cable.
  26. Dell Inspiron 15-7547 Keyboard Replacement: 手順 26、 3の画像 1 Dell Inspiron 15-7547 Keyboard Replacement: 手順 26、 3の画像 2 Dell Inspiron 15-7547 Keyboard Replacement: 手順 26、 3の画像 3
    • Unlatch black release on the ribbon cable.
    • Hold the blue flap to unplug the cable.
  27. Dell Inspiron 15-7547 Keyboard Replacement: 手順 27、 3の画像 1 Dell Inspiron 15-7547 Keyboard Replacement: 手順 27、 3の画像 2 Dell Inspiron 15-7547 Keyboard Replacement: 手順 27、 3の画像 3
    • Unlatch the ribbon cable by pulling the black release up.
    • Unlike the others, this release is found at the back.
    • Hold the flap and unplug the cable.
  28. Dell Inspiron 15-7547 Keyboard Replacement: 手順 28、 3の画像 1 Dell Inspiron 15-7547 Keyboard Replacement: 手順 28、 3の画像 2 Dell Inspiron 15-7547 Keyboard Replacement: 手順 28、 3の画像 3
    • Unlike the others this release is found at back.
    • Hold the blue flap and unplug the cable.
  29. Dell Inspiron 15-7547 Keyboard Replacement: 手順 29、 3の画像 1 Dell Inspiron 15-7547 Keyboard Replacement: 手順 29、 3の画像 2 Dell Inspiron 15-7547 Keyboard Replacement: 手順 29、 3の画像 3
    • Unplug the DC jack cable.
  30. Dell Inspiron 15-7547 Keyboard Replacement: 手順 30、 2の画像 1 Dell Inspiron 15-7547 Keyboard Replacement: 手順 30、 2の画像 2
    • Remove the seven 3.0 mm-long Philips #0 screws that secure the motherboard.
  31. Dell Inspiron 15-7547 Keyboard Replacement: 手順 31、 1の画像 1
    • Remove the motherboard from the laptop.
  32. Dell Inspiron 15-7547 Keyboard Replacement, Keyboard: 手順 32、 2の画像 1 Dell Inspiron 15-7547 Keyboard Replacement, Keyboard: 手順 32、 2の画像 2
    • Remove the five 2.0 mm-long Philips #00 screws from the metal back-plate.
  33. Dell Inspiron 15-7547 Keyboard Replacement: 手順 33、 3の画像 1 Dell Inspiron 15-7547 Keyboard Replacement: 手順 33、 3の画像 2 Dell Inspiron 15-7547 Keyboard Replacement: 手順 33、 3の画像 3
    • Peal away the two plastic covers marked GPU fan and CPU fan.
    • If never previously removed, these covers should be removed very gently so as to not tear the plastic underneath.
  34. Dell Inspiron 15-7547 Keyboard Replacement: 手順 34、 2の画像 1 Dell Inspiron 15-7547 Keyboard Replacement: 手順 34、 2の画像 2
    • Remove the twenty-two 2.0 mm-long Philips #00 screws that connect the keyboard to the chassis.
  35. Dell Inspiron 15-7547 Keyboard Replacement: 手順 35、 1の画像 1
    • Lift the the keyboard from the chassis.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Isaac Brooks
メンバー登録日: 09/10/18
355 ポイント
3のガイドは作成済み
チーム
Appalachian State University, Team S2-G4, Menagarishvili Fall 2018 Appalachian State University, Team S2-G4, Menagarishvili Fall 2018人のメンバー
APSU-MENAGARISHVILI-F18S2G4
3 メンバー
10のガイドは作成済み
コメント 1 件
I'm trying to source the 22 , 2.0 mm-long screws that connect the keyboard to the chassis but I dont know what the correct specifications to look for, can someone please help?
Marlon Fraser - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 38
今までの合計 2,304
