メインコンテンツにスキップ
Dell Inspiron 15-7537 Keyboard Replacement
必要な工具と部品
  1. Dell Inspiron 15-7537 Keyboard Replacement, Bottom Case: 手順 1、 1の画像 1
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 Keyboard Replacement: 手順 2、 1の画像 1
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 Keyboard Replacement: 手順 3、 1の画像 1
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 Keyboard Replacement, Battery: 手順 4、 1の画像 1
    • Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
  5. Dell Inspiron 15-7537 Keyboard Replacement: 手順 5、 1の画像 1
    • Ground the system board by turning over the computer, opening the display, and holding the power button down for about 5 seconds before proceeding.
    • Using the pull tab on the battery, lift the battery out of the computer.
  6. Dell Inspiron 15-7537 Keyboard Replacement, Removing the Keyboard: 手順 6、 1の画像 1
    • Remove the single 5mm screw that connects the keyboard to the palm assembly with the Phillips head screwdriver.
  7. Dell Inspiron 15-7537 Keyboard Replacement: 手順 7、 1の画像 1
    • Flip over the computer and open the display as far as it can go.
    • Use the spudger to remove the keyboard from the palm assembly.
  8. Dell Inspiron 15-7537 Keyboard Replacement: 手順 8、 1の画像 1
    • Gently flip over the keyboard and place it on the palm rest assembly.
    • Lift the connector latches and disconnect the keyboard and the keyboard back-light cables.
  9. Dell Inspiron 15-7537 Keyboard Replacement: 手順 9、 3の画像 1 Dell Inspiron 15-7537 Keyboard Replacement: 手順 9、 3の画像 2 Dell Inspiron 15-7537 Keyboard Replacement: 手順 9、 3の画像 3
    • Take the keyboard off the palm rest assembly.
終わりに
11 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jean Whitmore
メンバー登録日: 01/22/15
984 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 18-2, Maness Winter 2015 Cal Poly, Team 18-2, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S18G2
4 メンバー
8のガイドは作成済み
3 件のコメント
Great guide, thanks for the help!
Patrick S - 返信
Thanks It’s Useful
ahmed omar - 返信
It is important to note that the little black clips on the ends of the keyboard wires SWIVEL UP! I broke mine because nothing in this guide told me how to get the wires out properly.
benton.addison - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 32
今までの合計 6,647
