メインコンテンツにスキップ
Dell Inspiron 15-5567 Speakers Replacement
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. Dell Inspiron 15-5567 Speakers Replacement, Back Cover: 手順 1、 3の画像 1 Dell Inspiron 15-5567 Speakers Replacement, Back Cover: 手順 1、 3の画像 2 Dell Inspiron 15-5567 Speakers Replacement, Back Cover: 手順 1、 3の画像 3
    • Orient the laptop with the back cover facing upward and the INSPIRON engraving reads legible (not flipped).
    • Remove 13 M2.5x8mm screws using a Philips #0 screwdriver.
    • Remove two M2x4mm screws using the same screwdriver.
  2. Dell Inspiron 15-5567 Speakers Replacement: 手順 2、 2の画像 1 Dell Inspiron 15-5567 Speakers Replacement: 手順 2、 2の画像 2
    • Insert the blue plastic opening tool into the crease of the CD driver, and pop it open.
    • Slide the rest of it out with your hand.
  3. Dell Inspiron 15-5567 Speakers Replacement: 手順 3、 3の画像 1 Dell Inspiron 15-5567 Speakers Replacement: 手順 3、 3の画像 2 Dell Inspiron 15-5567 Speakers Replacement: 手順 3、 3の画像 3
    • Remove three M2x2mm screws underneath the CD driver with the same Philips #0 screwdriver.
    • Place the blue plastic opening tool in the crease of the cover and push it upward to open the back cover.
    • Grab the corners of the cover firmly and lift it up.
    • Some parts are weaker than others; open it gently from corners.
  4. Dell Inspiron 15-5567 Speakers Replacement, Remove the Screws: 手順 4、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the screws that secure the battery bracket to the system board and palm rest and keyboard assembly.
  5. Dell Inspiron 15-5567 Speakers Replacement, Removing the Battery Bracket: 手順 5、 1の画像 1
    • Lift and remove the battery bracket.
  6. Dell Inspiron 15-5567 Speakers Replacement, Remove the Screw: 手順 6、 1の画像 1
    • Remove the screw that secures the battery to the palm rest and keyboard assembly.
    • Note the location of the screw that secures the battery to the palm rest and keyboard assembly.
  7. Dell Inspiron 15-5567 Speakers Replacement, Lifting the Battery: 手順 7、 1の画像 1
    • Lift the battery off the palm rest and keyboard assembly.
  8. Dell Inspiron 15-5567 Speakers Replacement, Speakers: 手順 8、 3の画像 1 Dell Inspiron 15-5567 Speakers Replacement, Speakers: 手順 8、 3の画像 2 Dell Inspiron 15-5567 Speakers Replacement, Speakers: 手順 8、 3の画像 3
    • Remove the cable by using the blue plastic opening tool.
    • Lift the first speaker gently and remove it.
  9. Dell Inspiron 15-5567 Speakers Replacement: 手順 9、 1の画像 1
    • Lift the other speaker gently and remove it.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Sattam Bakolka
メンバー登録日: 01/14/20
732 ポイント
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 31
今までの合計 967
