はじめに
The hard drive is a primary storage component. If you are losing files or experience the Blue Screen of Death, this might be because of a faulty hard drive. This guide shows you how to remove your hard drive in order to replace it.
必要な工具と部品
Using a Phillips #0 screwdriver, unscrew the two 8mm screws from the panel.
Take a spudger and wedge it between the panel and the base of the device.
Push down on the spudger until you hear a click sound.
Slide the spudger along the panel and continue to push down until the panel is completely detached.
Remove the panel.
4 の人々がこのガイドを完成させました。
