メインコンテンツにスキップ
Dell Inspiron 15-5552 Memory Replacement
必要な工具と部品
  1. Dell Inspiron 15-5552 Memory Replacement, Battery: 手順 1、 1の画像 1
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 Memory Replacement: 手順 2、 1の画像 1
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 Memory Replacement: 手順 3、 1の画像 1
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 Memory Replacement: 手順 4、 2の画像 1 Dell Inspiron 15-5552 Memory Replacement: 手順 4、 2の画像 2
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
  5. Dell Inspiron 15-5552 Memory Replacement, Screw Location: 手順 5、 1の画像 1
    • Flip the device on its back, locate the screws circled.
  6. Dell Inspiron 15-5552 Memory Replacement, Screw Removal: 手順 6、 1の画像 1
    • Use a J0 screwdriver to unscrew the two, 6mm Phillips screw on the rear-cover.
  7. Dell Inspiron 15-5552 Memory Replacement, Removing Cover: 手順 7、 3の画像 1 Dell Inspiron 15-5552 Memory Replacement, Removing Cover: 手順 7、 3の画像 2 Dell Inspiron 15-5552 Memory Replacement, Removing Cover: 手順 7、 3の画像 3
    • Using a spudger, Lightly lift the rear-cover up and at an angle, away from the computer.
  8. Dell Inspiron 15-5552 Memory Replacement, RAM Removal: 手順 8、 2の画像 1 Dell Inspiron 15-5552 Memory Replacement, RAM Removal: 手順 8、 2の画像 2
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  9. Dell Inspiron 15-5552 Memory Replacement, RAM Removal Contiuned: 手順 9、 2の画像 1 Dell Inspiron 15-5552 Memory Replacement, RAM Removal Contiuned: 手順 9、 2の画像 2
    • Remove the dislodged up RAM by pulling it away from the connection.
    • If it does not pop up, pry it out in a steady and straight direction.
終わりに
作成者
4人の作成者と共同で作成されました。
Chandler Champion
メンバー登録日: 01/23/18
364 ポイント
3のガイドは作成済み
チーム
Western Carolina University, Team S1-G4, Virtue Spring 2018 Western Carolina University, Team S1-G4, Virtue Spring 2018人のメンバー
WCU-VIRTUE-S18S1G4
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 14
今までの合計 294
