メインコンテンツにスキップ
Dell Inspiron 15-5552 CD-Drive Replacement
必要な工具と部品
  1. Dell Inspiron 15-5552 CD-Drive Replacement, Battery: 手順 1、 1の画像 1
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 CD-Drive Replacement: 手順 2、 1の画像 1
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 CD-Drive Replacement: 手順 3、 1の画像 1
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 CD-Drive Replacement: 手順 4、 2の画像 1 Dell Inspiron 15-5552 CD-Drive Replacement: 手順 4、 2の画像 2
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
  5. Dell Inspiron 15-5552 CD-Drive Replacement, Keyboard: 手順 5、 2の画像 1 Dell Inspiron 15-5552 CD-Drive Replacement, Keyboard: 手順 5、 2の画像 2
    • Keyboard
    • Insert a spudger next to the 5 plastic indents located at the top of the keyboard and gently pry to release the securing clips.
  6. Dell Inspiron 15-5552 CD-Drive Replacement: 手順 6、 2の画像 1 Dell Inspiron 15-5552 CD-Drive Replacement: 手順 6、 2の画像 2
    • Lift the keyboard off of the computer. *Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.*
  7. Dell Inspiron 15-5552 CD-Drive Replacement: 手順 7、 1の画像 1
    • Flip the keyboard over onto the palm-rest assembly.
  8. Dell Inspiron 15-5552 CD-Drive Replacement: 手順 8、 2の画像 1 Dell Inspiron 15-5552 CD-Drive Replacement: 手順 8、 2の画像 2
    • Flip the black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
  9. Dell Inspiron 15-5552 CD-Drive Replacement, CD-Drive: 手順 9、 1の画像 1
    • CD-Drive
    • Flip the computer over, *screen down* and unscrew the 1 screw in the middle located below the battery with a J0 bit tipped screwdriver.
  10. Dell Inspiron 15-5552 CD-Drive Replacement: 手順 10、 1の画像 1
    • Next using the J0 bit tipped screwdriver unscrew the 2 remaining screws shown in the picture.
  11. Dell Inspiron 15-5552 CD-Drive Replacement: 手順 11、 2の画像 1 Dell Inspiron 15-5552 CD-Drive Replacement: 手順 11、 2の画像 2
    • After all 3 screws are removed take a spudger and pry the CD-Drive out of the computer.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Chandler Champion
メンバー登録日: 01/23/18
364 ポイント
3のガイドは作成済み
チーム
Western Carolina University, Team S1-G4, Virtue Spring 2018 Western Carolina University, Team S1-G4, Virtue Spring 2018人のメンバー
WCU-VIRTUE-S18S1G4
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 11
今までの合計 166
