Flip the device over so the bottom is facing up.
Using a #0 Phillips screwdriver, remove the 4.0mm screw to the right of the disk drive.
Turn the device over and open it.
You will see 5 notches at the top of the keyboard.
Stick the end of the metal spudger between each of these notches to pry the keyboard up. Once you hear a pop sound, stop and move onto the next notch.
Once all five notches at the top of the keyboard are loosened, begin pulling it up from the top.
Pull the keyboard up slowly so you don't tear the ribbon cable out or damage it.
To remove the ribbon cable, use the metal spudger tool to pop the ribbon cable lock up.
After popping up the ribbon cable lock, you can pull the ribbon cable out and sit the keyboard to the side.
Using a #0 Phillips screwdriver, remove the three 4.0mm screws on the front where the keyboard used to be.
On the front of the device, there will be two ribbon cables. Remove them using the following directions:
Pull the black cable ribbon lock up and pull the blue ribbon out using the tab.
Pull the white cable ribbon lock up and pull the blue ribbon out using the tab .
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
