この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Is the touchpad in your Dell Inspiron 15-3543 not working properly, sticking down, or is unresponsive?
If so, here is the guide to fix the problem by simply replacing your touchpad. You will need the #0 Phillips screwdriver and opening tools, in order to remove the 19 screws involved with this replacement and pry the top panel from the bottom panel.
必要な工具と部品
Flip the device over so the bottom is facing up.
Using a #0 Phillips screwdriver, remove the 4.0mm screw to the right of the disk drive.
ある他の人がこのガイドを完成しました。
