メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
Dell Inspiron 15-3521 Motherboard Replacement
必要な工具と部品
  1. Dell Inspiron 15-3521 Motherboard Replacement, Remove the battery: 手順 1、 3の画像 1 Dell Inspiron 15-3521 Motherboard Replacement, Remove the battery: 手順 1、 3の画像 2 Dell Inspiron 15-3521 Motherboard Replacement, Remove the battery: 手順 1、 3の画像 3
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 Motherboard Replacement, Remove access door: 手順 2、 3の画像 1 Dell Inspiron 15-3521 Motherboard Replacement, Remove access door: 手順 2、 3の画像 2 Dell Inspiron 15-3521 Motherboard Replacement, Remove access door: 手順 2、 3の画像 3
    • Loosen the two screws attaching the access door to the laptop body
    • Using a spudger, pry open the access door from the laptop
    • Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
  3. Dell Inspiron 15-3521 Motherboard Replacement, Memory Card Removal/Replacement: 手順 3、 3の画像 1 Dell Inspiron 15-3521 Motherboard Replacement, Memory Card Removal/Replacement: 手順 3、 3の画像 2 Dell Inspiron 15-3521 Motherboard Replacement, Memory Card Removal/Replacement: 手順 3、 3の画像 3
    • To access the memory cards, push out the latches on the left and right of the memory cards
    • To remove the memory card, pull it out of the tray with the latches still stretched out
    • Insert a new memory card in to the memory card tray, depressing until side latches engage with a click.
  4. Dell Inspiron 15-3521 Motherboard Replacement, Removing Underside Screws: 手順 4、 1の画像 1
    • Before flipping the laptop right-side up, remove screws holding the back plate to the laptop frame
    • Remove the backplate screws using a phillips head PH0 screwdriver (11).
    • Remove the screws located underneath the battery and access panel using the same phillips head PH0 screwdriver (3).
  5. Dell Inspiron 15-3521 Motherboard Replacement, Removing the Keyboard: 手順 5、 2の画像 1 Dell Inspiron 15-3521 Motherboard Replacement, Removing the Keyboard: 手順 5、 2の画像 2
    • Flip the laptop right-side-up
    • Using a spudger, separate the keyboard from the laptop frame.
    • Using fingers to remove the keyboard from the laptop frame, be careful not to damage the keyboard cable.
  6. Dell Inspiron 15-3521 Motherboard Replacement, Disconnecting the Keyboard Cable: 手順 6、 3の画像 1 Dell Inspiron 15-3521 Motherboard Replacement, Disconnecting the Keyboard Cable: 手順 6、 3の画像 2 Dell Inspiron 15-3521 Motherboard Replacement, Disconnecting the Keyboard Cable: 手順 6、 3の画像 3
    • To disconnect the keyboard, locate the keyboard cable locking mechanism.
    • Open the locking mechanism by gently pulling up.
    • Slide out the keyboard cable from the interface to separate the keyboard from the laptop.
  7. Dell Inspiron 15-3521 Motherboard Replacement, Underneath the Keyboard: 手順 7、 3の画像 1 Dell Inspiron 15-3521 Motherboard Replacement, Underneath the Keyboard: 手順 7、 3の画像 2 Dell Inspiron 15-3521 Motherboard Replacement, Underneath the Keyboard: 手順 7、 3の画像 3
    • Locate the wireless card location underneath the removed keyboard.
    • Disengage the antenna cables connecting the laptop to the wireless card.
    • Using a phillips head PH0 screwdriver, unscrew the single screw holding the wireless card to the laptop frame.
    • Remove the wireless card.
  8. Dell Inspiron 15-3521 Motherboard Replacement, Disconnect the Palmrest Cables: 手順 8、 2の画像 1 Dell Inspiron 15-3521 Motherboard Replacement, Disconnect the Palmrest Cables: 手順 8、 2の画像 2
    • Unplug the palmrest cables, which are denoted by a blue and a purple marking.
    • To remove, lift up the locking tab and pull the cables from their laptop interface.
  9. Dell Inspiron 15-3521 Motherboard Replacement, Removing Palmrest Screws: 手順 9、 1の画像 1
    • Remove the four 2.5 mm by 5 mm screws underneath the keyboard plate using a phillips head PH0 screwdriver.
    • Remove the three 2 mm by 3 mm screws underneath the keyboard plate using a phillips head PH0 screwdriver.
  10. Dell Inspiron 15-3521 Motherboard Replacement, Disconnecting the Palmrest: 手順 10、 2の画像 1 Dell Inspiron 15-3521 Motherboard Replacement, Disconnecting the Palmrest: 手順 10、 2の画像 2
    • Using a spudger, separate the palmrest from the base of the laptop. This interface is located around the equator of the laptop.
    • Use your fingers to completely remove the palmrest from the laptop base.
  11. Dell Inspiron 15-3521 Motherboard Replacement, Cables to Separate from the Motherboard 1: 手順 11、 3の画像 1 Dell Inspiron 15-3521 Motherboard Replacement, Cables to Separate from the Motherboard 1: 手順 11、 3の画像 2 Dell Inspiron 15-3521 Motherboard Replacement, Cables to Separate from the Motherboard 1: 手順 11、 3の画像 3
    • First, remove the power cable, located in the upper left hand side of the laptop. This can be removed using forceps or using your fingers.
    • Second, remove the LCD cable located in the upper center of the laptop. This cablemust be removed using the same unlocking procedure as the palmrest cables used in step 6.
    • The first image shown has the wireless card still connected, however, for removal of the power cable, removing the wireless card is necessary in revealing the power cable. See second image.
  12. Dell Inspiron 15-3521 Motherboard Replacement, Cables to Separate from the Motherboard 2: 手順 12、 3の画像 1 Dell Inspiron 15-3521 Motherboard Replacement, Cables to Separate from the Motherboard 2: 手順 12、 3の画像 2 Dell Inspiron 15-3521 Motherboard Replacement, Cables to Separate from the Motherboard 2: 手順 12、 3の画像 3
    • Third, unplug the speaker cables using forceps or by using your fingers.
    • Fourth, unplug the final cable, denoted by a purple plastic flag. This cable uses the same locking mechanism as the palmrest cables seen in step 6.
    • The final cable is shown detached in the first image.
  13. Dell Inspiron 15-3521 Motherboard Replacement, Remove the motherboard: 手順 13、 2の画像 1 Dell Inspiron 15-3521 Motherboard Replacement, Remove the motherboard: 手順 13、 2の画像 2
    • Unscrew the motherboard from the laptop frame using a phillips head PH0 screwdriver.
    • Then, use your fingers to remove the motherboard from the laptop.
終わりに
24 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Stephen Landeene
メンバー登録日: 10/13/14
422 ポイント
2のガイドは作成済み
チーム
Clemson, Team 3-1, Benson Fall 2014 Clemson, Team 3-1, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S3G1
4 メンバー
9のガイドは作成済み
2 件のコメント
masumahamad877@gmail.com
masumahamad877 - 返信
01711377875 ,02 9613003
masumahamad877 - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 30
今までの合計 17,602
