メインコンテンツにスキップ
Dell Inspiron 15-3521 Hard Drive Replacement
必要な工具と部品
  1. Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: 手順 1、 3の画像 1 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: 手順 1、 3の画像 2 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: 手順 1、 3の画像 3
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: 手順 2、 3の画像 1 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: 手順 2、 3の画像 2 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: 手順 2、 3の画像 3
    • Loosen the two screws attaching the access door to the laptop body.
    • Using a spudger, pry open the access door from the laptop.
    • Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
  3. Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: 手順 3、 3の画像 1 Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: 手順 3、 3の画像 2 Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: 手順 3、 3の画像 3
    • Locate the two hard drive screws, located on the left-hand side of the hard drive casing.
    • Loosen and remove these screws using a phillips head screw driver PH0.
    • Push the hard drive to the left, and then lift out of the laptop casing to remove from laptop.
  4. Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: 手順 4、 3の画像 1 Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: 手順 4、 3の画像 2 Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: 手順 4、 3の画像 3
    • Identify the Hard Drive caddy screws, one on each side of the hard drive casing.
    • Remove these screws using a phillips head PH0 screwdriver.
    • Now, with a new hard drive, attach the caddy/casing using the same screws removed from the old hard drive.
終わりに
28 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Andrew Dippre
メンバー登録日: 10/13/14
2,902 ポイント
7のガイドは作成済み
チーム
Clemson, Team 3-1, Benson Fall 2014 Clemson, Team 3-1, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S3G1
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 55
今までの合計 32,966
