必要な工具と部品
Close the laptop and place it so that the back of the screen is lying flat on your work surface.
Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
Remove the 5mm long Phillips #0 screw that is holding the optical drive in place, as pictured.
You can now slide the optical disk drive out of the computer.
3 の人々がこのガイドを完成させました。
