メインコンテンツにスキップ
Dell Inspiron 15 Gaming 7566 Hard Drive Replacement
必要な工具と部品
  1. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Lifting the Latch: 手順 1、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: The latch on the hard-drive locking connector is fragile. Pulling the latch forcefully may damage the hard-drive locking connector. Exercise care when handling the latch on the hard-drive locking connector.
    • Using a plastic scribe, lift the latch and use the pull tab to disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Remove the Screws: 手順 2、 1の画像 1
    • Remove the four screws (M2.5x3 Ladder type) that secure the hard-drive assembly to the computer base.
  3. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Lifting the Hard Drive Assembly: 手順 3、 1の画像 1
    • Lift the hard-drive assembly, along with its cable, off the computer base.
  4. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Disconnect the Interposer: 手順 4、 1の画像 1
    • Disconnect the interposer from the hard-drive assembly.
  5. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Remove the Screws: 手順 5、 1の画像 1
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Align the Screw Holes: 手順 6、 1の画像 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  7. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Replace the Screws: 手順 7、 1の画像 1
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive
  8. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Connect the Interposer: 手順 8、 1の画像 1
    • Connect the interposer to the hard-drive assembly.
  9. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Align the Screw Holes: 手順 9、 1の画像 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  10. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Replace the Screws: 手順 10、 1の画像 1
    • Replace the four screws (M2.5x3 Ladder type) that secure the hard-drive assembly to the computer base.
  11. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Connecting the Hard Drive Cable: 手順 11、 1の画像 1
    • Connect the hard-drive cable to the system board and close the latch to secure the hard-drive cable.
ゴール
作成者
1人の作成者と共同作成されました。
Terrence15
メンバー登録日: 12/18/17
79,161 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
42 メンバー
1,989のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 10
今までの合計 678
