メインコンテンツにスキップ
Dell Inspiron 15 7591 2-in-1 Battery Replacement
必要な工具と部品
  1. Dell Inspiron 15 7591 2-in-1 Battery Replacement, Opening the Laptop: 手順 1、 2の画像 1 Dell Inspiron 15 7591 2-in-1 Battery Replacement, Opening the Laptop: 手順 1、 2の画像 2
    • Unscrew the 7 Philips #000 screws.
    • Loosen the 2 Philips #000 screws. These screws do not come out but rather stay attached to the case.
    • With a suction cup lift the top and insert a plastic pry tool or guitar pick. Slide the pry tool from left to right. The panel should pop out slightly.
    • Work downwards with a pry tool on the right and left sides. The panel should pop up and be able to be removed.
  2. Dell Inspiron 15 7591 2-in-1 Battery Replacement, Removing the Battery: 手順 2、 1の画像 1
    • Remove the 2 Philips #000 screws.
    • Loosen the Philips #000 screws. The screw is attached to the battery and will remain attached to the battery.
  3. Dell Inspiron 15 7591 2-in-1 Battery Replacement, Disconnecting the Battery: 手順 3、 1の画像 1
    • Flip the battery upside down onto the motherboard.
    • Snake the wire out of its housing.
    • Disconnect the power connector.
  4. Dell Inspiron 15 7591 2-in-1 Battery Replacement: 手順 4、 1の画像 1
    • Slide the battery in with the bottom first in order to attach the latches that are at the bottom.
    • Screw in the 2 Phillips #000 screws and tighten the 1 Phillips #000 screw attached to the battery.
終わりに
To reassemble your device, follow these instructions in reverse order. When re-attaching the bottom panel be careful when tightening the screws near the trackpad. If these screws are over tightened it can prevent the trackpad from being clicked.
作成者
2人の作成者と共同で作成されました。
Griffin Nott
メンバー登録日: 04/29/22
181 ポイント
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 31
今までの合計 976
