メインコンテンツにスキップ
Dell Inspiron 15 7590 2-in-1 Keys Replacement
必要な工具と部品
  1. Dell Inspiron 15 7590 2-in-1 Keys Replacement, Keys: 手順 1、 2の画像 1 Dell Inspiron 15 7590 2-in-1 Keys Replacement, Keys: 手順 1、 2の画像 2
    • Position a spudger between the key cap and its hinge.
    • Push up with steady force to snap the key cap away from the hinge.
    • Use a spudger to pry under the corners of the hinge to remove it.
    • Remember the orientation of your key hinge and which holes go to the upper metal holders.
  2. Dell Inspiron 15 7590 2-in-1 Keys Replacement: 手順 2、 2の画像 1 Dell Inspiron 15 7590 2-in-1 Keys Replacement: 手順 2、 2の画像 2
    • Align the new hinge with the metal holders on the keyboard.
    • Push the hinge into place and lock it onto the metal holders.
    • Make sure the hinge lies flat on the metal holders. If it doesn't, check the orientation of the hinge.
  3. Dell Inspiron 15 7590 2-in-1 Keys Replacement: 手順 3、 2の画像 1 Dell Inspiron 15 7590 2-in-1 Keys Replacement: 手順 3、 2の画像 2
    • Flip the key cap over and determine the positions of the spikes jutting out.
    • Align the spikes with the holes on the hinge and press the key cap onto the hinge.
  4. Dell Inspiron 15 7590 2-in-1 Keys Replacement: 手順 4、 1の画像 1
    • Press down on the key to snap it into place.
  5. Dell Inspiron 15 7590 2-in-1 Keys Replacement: 手順 5、 3の画像 1 Dell Inspiron 15 7590 2-in-1 Keys Replacement: 手順 5、 3の画像 2 Dell Inspiron 15 7590 2-in-1 Keys Replacement: 手順 5、 3の画像 3
    • To replace big keys, examine the other side of the key cap and locate the metal wires attached to the holders on the back of the key.
    • Examine the space the key will enter, and locate the metal holders with holes in them.
    • Position the key so all the metal ends can enter a hole and insert the metal ends into the holes.
    • Push down on the key and adjust the keycap to make sure its metal attachments slide into their holders.
終わりに
If you encountered unsolvable difficulties replacing a key, make sure it’s aligned properly and crosscheck that the key is the same model as your laptop.
作成者
2人の作成者と共同で作成されました。
Ojonukpemi F Ameh
メンバー登録日: 03/22/21
121 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team S1-G1, Sinclaire Spring 2021 UMass Dartmouth, Team S1-G1, Sinclaire Spring 2021人のメンバー
UMASSD-SINCLAIRE-S21S1G1
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 83
今までの合計 2,603
