メインコンテンツにスキップ
Dell Inspiron 15 7579 Motherboard Replacement
必要な工具と部品
  1. Dell Inspiron 15 7579 Motherboard Replacement, Back Panel: 手順 1、 1の画像 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Motherboard Replacement: 手順 2、 2の画像 1 Dell Inspiron 15 7579 Motherboard Replacement: 手順 2、 2の画像 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Motherboard Replacement, Fan: 手順 3、 2の画像 1 Dell Inspiron 15 7579 Motherboard Replacement, Fan: 手順 3、 2の画像 2
    • Remove the two 7.9 mm screws from the fan with a Phillips #0 screwdriver.
  4. Dell Inspiron 15 7579 Motherboard Replacement: 手順 4、 2の画像 1 Dell Inspiron 15 7579 Motherboard Replacement: 手順 4、 2の画像 2
    • Unplug the wires from the port.
    • Be sure to pull from the plastic connector, not the wires.
  5. Dell Inspiron 15 7579 Motherboard Replacement: 手順 5、 1の画像 1
    • Carefully lift the fan out of the computer.
  6. Dell Inspiron 15 7579 Motherboard Replacement, SSD M.2 Drive: 手順 6、 1の画像 1
    • Remove the single 3.6 mm screw holding the left side of the M.2 SSD card with a Phillips PH0 screwdriver.
  7. Dell Inspiron 15 7579 Motherboard Replacement: 手順 7、 1の画像 1
    • Gently pull out the SSD card at the angle it is relaxed in to remove it. It is easiest to do this by hand.
    • Be gentle when pulling the SSD card out. It should take little effort to get it to slide out properly.
  8. Dell Inspiron 15 7579 Motherboard Replacement, Motherboard: 手順 8、 2の画像 1 Dell Inspiron 15 7579 Motherboard Replacement, Motherboard: 手順 8、 2の画像 2
    • Remove the six 2.1 mm screws with the Phillips #0 screwdriver.
  9. Dell Inspiron 15 7579 Motherboard Replacement: 手順 9、 2の画像 1 Dell Inspiron 15 7579 Motherboard Replacement: 手順 9、 2の画像 2
    • Unplug the eight ribbon cables connected to the motherboard.
  10. Dell Inspiron 15 7579 Motherboard Replacement: 手順 10、 1の画像 1
    • Lift the motherboard up from the side opposite of the external ports and remove it from the laptop.
終わりに
作成者
3人の作成者と共同で作成されました。
Musukula P McClain
メンバー登録日: 09/20/21
97 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 14
今までの合計 571
