メインコンテンツにスキップ
Dell Inspiron 15 7579 Display Replacement
必要な工具と部品
  1. Dell Inspiron 15 7579 Display Replacement, Back Panel: 手順 1、 1の画像 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Display Replacement: 手順 2、 2の画像 1 Dell Inspiron 15 7579 Display Replacement: 手順 2、 2の画像 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Display Replacement, Fan: 手順 3、 2の画像 1 Dell Inspiron 15 7579 Display Replacement, Fan: 手順 3、 2の画像 2
    • Remove the two 7.9 mm screws from the fan with a Phillips #0 screwdriver.
  4. Dell Inspiron 15 7579 Display Replacement: 手順 4、 2の画像 1 Dell Inspiron 15 7579 Display Replacement: 手順 4、 2の画像 2
    • Unplug the wires from the port.
    • Be sure to pull from the plastic connector, not the wires.
  5. Dell Inspiron 15 7579 Display Replacement: 手順 5、 1の画像 1
    • Carefully lift the fan out of the computer.
  6. Dell Inspiron 15 7579 Display Replacement, SSD M.2 Drive: 手順 6、 1の画像 1
    • Remove the single 3.6 mm screw holding the left side of the M.2 SSD card with a Phillips PH0 screwdriver.
  7. Dell Inspiron 15 7579 Display Replacement: 手順 7、 1の画像 1
    • Gently pull out the SSD card at the angle it is relaxed in to remove it. It is easiest to do this by hand.
    • Be gentle when pulling the SSD card out. It should take little effort to get it to slide out properly.
  8. Dell Inspiron 15 7579 Display Replacement, Motherboard: 手順 8、 2の画像 1 Dell Inspiron 15 7579 Display Replacement, Motherboard: 手順 8、 2の画像 2
    • Remove the six 2.1 mm screws with the Phillips #0 screwdriver.
  9. Dell Inspiron 15 7579 Display Replacement: 手順 9、 2の画像 1 Dell Inspiron 15 7579 Display Replacement: 手順 9、 2の画像 2
    • Unplug the eight ribbon cables connected to the motherboard.
  10. Dell Inspiron 15 7579 Display Replacement: 手順 10、 1の画像 1
    • Lift the motherboard up from the side opposite of the external ports and remove it from the laptop.
  11. Dell Inspiron 15 7579 Display Replacement, Display: 手順 11、 2の画像 1 Dell Inspiron 15 7579 Display Replacement, Display: 手順 11、 2の画像 2
    • Remove the screw that holds the Wi-Fi card in place with a Phillips #0 screwdriver.
    • Disconnect the black and white coaxial cables from the Wi-Fi card.
    • Remove the Wi-Fi card from its port.
  12. Dell Inspiron 15 7579 Display Replacement: 手順 12、 2の画像 1 Dell Inspiron 15 7579 Display Replacement: 手順 12、 2の画像 2
    • Remove the two screws from the metal plates with the Phillips #0 screwdriver.
  13. Dell Inspiron 15 7579 Display Replacement: 手順 13、 3の画像 1 Dell Inspiron 15 7579 Display Replacement: 手順 13、 3の画像 2 Dell Inspiron 15 7579 Display Replacement: 手順 13、 3の画像 3
    • Lift up the two hinges perpendicularly to the board beneath it.
    • It may be difficult to lift up the hinges, so it may take some force to remove them.
    • Lift up on the keyboard at an angle from the laptop and gently pull away from hinges.
終わりに
作成者
2人の作成者と共同で作成されました。
Andrew Steven McNay
メンバー登録日: 09/20/21
97 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 22
今までの合計 1,288
