はじめに
In this guide, we will be showing you how to remove and replace the Memory Module.
Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
Align the notch on the NEW memory module with the tab on the memory-module slot.
Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
もう少しです!
ゴール
ある他の人がこのガイドを完成しました。
