メインコンテンツにスキップ
Dell Inspiron 15 5584 RAM Replacement
必要な工具と部品
  1. Dell Inspiron 15 5584 RAM Replacement, Bottom Cover: 手順 1、 1の画像 1
    • Make sure to turn off and unplug your laptop before starting.
    • Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
  2. Dell Inspiron 15 5584 RAM Replacement: 手順 2、 3の画像 1 Dell Inspiron 15 5584 RAM Replacement: 手順 2、 3の画像 2 Dell Inspiron 15 5584 RAM Replacement: 手順 2、 3の画像 3
    • Remove the seven 7 mm screws from the bottom using a Phillips #0 screwdriver.
    • Loosen the two captive back corner screws using a Phillips #0 screwdriver.
    • The two corner screws are not removable. A clicking sounds indicates that the screw is fully loosened.
  3. Dell Inspiron 15 5584 RAM Replacement: 手順 3、 2の画像 1 Dell Inspiron 15 5584 RAM Replacement: 手順 3、 2の画像 2
    • Slide an iFixit opening tool underneath the right side USB port and the keyboard.
    • Gently trace the iFixit opening tool along the entire outer rim of the laptop, carefully applying an upwards pressure.
    • Be careful not to force open the plate or push too much off without loosening the other sides. This can cause the bottom cover to crack.
  4. Dell Inspiron 15 5584 RAM Replacement: 手順 4、 2の画像 1 Dell Inspiron 15 5584 RAM Replacement: 手順 4、 2の画像 2
    • Gently pry off the bottom cover from the laptop.
    • Use the iFixit opening tool to loosen any spots you may have missed from Step 3.
  5. Dell Inspiron 15 5584 RAM Replacement, Battery: 手順 5、 2の画像 1 Dell Inspiron 15 5584 RAM Replacement, Battery: 手順 5、 2の画像 2
    • Remove the four 3.5 mm screws holding the battery down with a JIS #0 screwdriver.
  6. Dell Inspiron 15 5584 RAM Replacement: 手順 6、 3の画像 1 Dell Inspiron 15 5584 RAM Replacement: 手順 6、 3の画像 2 Dell Inspiron 15 5584 RAM Replacement: 手順 6、 3の画像 3
    • Detach the motherboard connector tab from the top left of the battery.
    • Remove the battery from the device.
    • Be sure to carefully wiggle the connector out from the battery socket. Ripping it out too forcefully could damage the socket.
  7. Dell Inspiron 15 5584 RAM Replacement, RAM: 手順 7、 1の画像 1
    • Firmly apply pressure on the two latches to the right and left of the RAM stick.
  8. Dell Inspiron 15 5584 RAM Replacement: 手順 8、 1の画像 1
    • At an angle, gently pull the RAM stick out of the socket.
    • Remove the RAM stick from the motherboard socket.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Sam Vorn
メンバー登録日: 03/29/22
977 ポイント
9のガイドは作成済み
チーム
UMass Dartmouth, Team 1-1, Mellen Spring 2022 UMass Dartmouth, Team 1-1, Mellen Spring 2022人のメンバー
UMASSD-MELLEN-S22S1G1
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 25
今までの合計 308
