はじめに
Use this guide to replace the DC jack in your Dell Inspiron 15 5584.
The DC jack is a piece of hardware that allows for the intake of charge to your battery, and therefore, power to the rest of your computer. If the DC jack fails, your laptop will not take charge and will eventually lose power, becoming unable to function.
Before using this guide, ensure that the issue is not your charger or wall outlet. Utilize caution when removing the DC jack as it is linked into the motherboard, which is sensitive and easy to damage. Furthermore, ensure your device's battery is drained and your device is shut off.
必要な工具と部品
Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
Remove the three 6 mm screws holding down the screen hinge in the upper right corner using a JIS #0 screwdriver.
ある他の人がこのガイドを完成しました。
コメント 1 件
it is important to replace an OEM and New dc jack, you may check these pages:
https://www.dcjks.com/dell-inspiron-5584...
Amazon.com: Laptop DC Power Jack for DELL Inspiron 15 5584 P85F 0TM5N3 TM5N3 New : Electronics
