メインコンテンツにスキップ
Dell Inspiron 15 5579 2-in-1 Hard Drive Replacement
必要な工具と部品
  1. Dell Inspiron 15 5579 2-in-1 Hard Drive Replacement, Disconnect the Hard Drive Cable: 手順 1、 2の画像 1 Dell Inspiron 15 5579 2-in-1 Hard Drive Replacement, Disconnect the Hard Drive Cable: 手順 1、 2の画像 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Using the pull tab, disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15 5579 2-in-1 Hard Drive Replacement, Peel off the Tape: 手順 2、 1の画像 1
    • Peel off the tape that secures the hard-drive cable to the palm rest and keyboard assembly.
  3. Dell Inspiron 15 5579 2-in-1 Hard Drive Replacement, Noting the Hard Drive Cable: 手順 3、 1の画像 1
    • Note the hard-drive cable routing and remove the cable from the routing guides.
  4. Dell Inspiron 15 5579 2-in-1 Hard Drive Replacement, Remove the Screws: 手順 4、 1の画像 1
    • Remove the three screws (M2x3) that secure the hard-drive assembly to the palm rest and keyboard assembly.
  5. Dell Inspiron 15 5579 2-in-1 Hard Drive Replacement, Lifting the Hard-Drive Assembly: 手順 5、 1の画像 1
    • Lift the hard-drive assembly along with its cable off the palm rest and keyboard assembly.
  6. Dell Inspiron 15 5579 2-in-1 Hard Drive Replacement, Disconnect the Interposer: 手順 6、 1の画像 1
    • Disconnect the interposer from the hard-drive assembly.
  7. Dell Inspiron 15 5579 2-in-1 Hard Drive Replacement, Remove the Screws: 手順 7、 1の画像 1
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15 5579 2-in-1 Hard Drive Replacement, Lifting the Hard Drive: 手順 8、 2の画像 1 Dell Inspiron 15 5579 2-in-1 Hard Drive Replacement, Lifting the Hard Drive: 手順 8、 2の画像 2
    • Lift the hard drive off the hard-drive bracket.
  9. Dell Inspiron 15 5579 2-in-1 Hard Drive Replacement, Align the Screw Holes: 手順 9、 1の画像 1
    • Align the screw holes on the NEW hard-drive bracket with the screw holes on the hard drive.
  10. Dell Inspiron 15 5579 2-in-1 Hard Drive Replacement, Replace the Screws: 手順 10、 1の画像 1
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  11. Dell Inspiron 15 5579 2-in-1 Hard Drive Replacement, Connect the Interposer: 手順 11、 1の画像 1
    • Connect the interposer to the hard-drive assembly.
  12. Dell Inspiron 15 5579 2-in-1 Hard Drive Replacement, Align the Screw Holes: 手順 12、 1の画像 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly.
  13. Dell Inspiron 15 5579 2-in-1 Hard Drive Replacement, Replace the Screws: 手順 13、 1の画像 1
    • Replace the screws three (M2x3) that secure the hard-drive assembly to the palm rest and keyboard assembly.
  14. Dell Inspiron 15 5579 2-in-1 Hard Drive Replacement, Routing the Hard Drive: 手順 14、 1の画像 1
    • Route the hard-drive cable through the routing guides on the palm rest and keyboard assembly.
  15. Dell Inspiron 15 5579 2-in-1 Hard Drive Replacement, Connecting the Hard-Drive Cable: 手順 15、 1の画像 1
    • Connect the hard-drive cable to the system board.
  16. Dell Inspiron 15 5579 2-in-1 Hard Drive Replacement, Adhering the Tape: 手順 16、 1の画像 1
    • Adhere the tape that secures the hard-drive cable to the palm rest and keyboard assembly.
ゴール
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Terrence15
メンバー登録日: 12/18/17
79,243 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
42 メンバー
1,989のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 2,297
