メインコンテンツにスキップ
Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement
必要な工具と部品
  1. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Turn the Computer Over: 手順 1、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Turn the computer over and open the display to 180-degree angle.
    • CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
  2. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Placing the Computer: 手順 2、 1の画像 1
    • Place the computer on a flat surface with the display facing down.
  3. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Remove the Screws: 手順 3、 1の画像 1
    • Remove the two screws (M2.5x7) that secure the display assembly to the palm rest and keyboard assembly.
  4. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Remove the Antenna Cables: 手順 4、 1の画像 1
    • Remove the antenna cables from the routing guide on the palm rest and keyboard assembly.
  5. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Lifting the Display Assembly: 手順 5、 1の画像 1
    • Lift the display assembly off the palm rest and keyboard assembly.
  6. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Align the Screw Holes: 手順 6、 1の画像 1
    • With the display facing down, align the screw holes on the display hinges with the screw holes on the palm rest and keyboard assembly.
  7. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Replace the Screws: 手順 7、 1の画像 1
    • Replace the two screws (M2.5x7) that secure the display assembly to the palm rest and keyboard assembly.
  8. Dell Inspiron 15 5579 2-in-1 Display Assembly Replacement, Turn the Computer Over: 手順 8、 1の画像 1
    • Turn the computer over and close the display.
ゴール
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Terrence15
メンバー登録日: 12/18/17
79,243 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
42 メンバー
1,989のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 18
今までの合計 1,795
