メインコンテンツにスキップ
Dell Inspiron 15 5577 Gaming Laptop RAM Replacement
必要な工具と部品
  1. Dell Inspiron 15 5577 Gaming Laptop RAM Replacement, RAM: 手順 1、 2の画像 1 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement, RAM: 手順 1、 2の画像 2
    • Before working inside your laptop, read the safety information that came with the laptop and follow the steps "When Working Inside Your Device."
    • Shut down the device by holding down the power button for a few seconds.
    • Remove the power cable from the device.
  2. Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 手順 2、 3の画像 1 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 手順 2、 3の画像 2 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 手順 2、 3の画像 3
    • Flip the device over so that the bottom is facing up.
    • With a Phillips #00 screwdriver, loosen the screw located at the top of the base panel.
    • Loosen the screw so that it is removed from the insert but is still connected to the base panel. This will create an opening for the next step.
  3. Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 手順 3、 3の画像 1 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 手順 3、 3の画像 2 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 手順 3、 3の画像 3
    • Use a spudger to gently pry up the top of the base panel until it pops loose.
    • Continue along the edges.
    • The corners may require a bit more force to pop loose, but refrain from applying excessive force.
  4. Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 手順 4、 2の画像 1 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 手順 4、 2の画像 2
    • Remove the laptop base panel.
  5. Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 手順 5、 3の画像 1 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 手順 5、 3の画像 2 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 手順 5、 3の画像 3
    • Use your fingertips to spread apart the securing-clips on both ends of the slot until the RAM stick pops up.
    • Remove the RAM stick.
  6. Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 手順 6、 3の画像 1 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 手順 6、 3の画像 2 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 手順 6、 3の画像 3
    • Align the notch of the new RAM stick with the tab in the slot.
    • Firmly slide the new RAM in the slot at an angle.
    • Press down until both secure-clips click into place.
    • If you do not hear the click, remove and reinstall the RAM stick again.
  7. Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 手順 7、 3の画像 1 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 手順 7、 3の画像 2 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 手順 7、 3の画像 3
    • Replace the base panel.
    • Firmly press on the edges of the base panel until it is clicked in.
    • Tighten the screw at the top of the base panel.
ゴール
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
John Lacadin
メンバー登録日: 09/17/20
172 ポイント
1ガイドが承認済み
チーム
York University, Team S2-G10, Melo-Thaiss Spring 2020 York University, Team S2-G10, Melo-Thaiss Spring 2020人のメンバー
YORK-MELO-THAISS-S20S2G10
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 37
今までの合計 1,133
