メインコンテンツにスキップ
Dell Inspiron 15 3593 Battery Replacement
必要な工具と部品
  1. Dell Inspiron 15 3593 Battery Replacement, Battery: 手順 1、 2の画像 1 Dell Inspiron 15 3593 Battery Replacement, Battery: 手順 1、 2の画像 2
    • First, make sure the computer is turned off and unplugged.
    • Turn the computer upside down so its backside is facing you and place on a flat and clean surface to work.
    • Use a Phillips #0 screwdriver to remove six (M2.5x7mm) screws, three (M2x2mm) screws, and one (M2x4mm) screw.
    • Remove the optical drive.
  2. Dell Inspiron 15 3593 Battery Replacement: 手順 2、 2の画像 1 Dell Inspiron 15 3593 Battery Replacement: 手順 2、 2の画像 2
    • Turn the laptop over and open the lid so the screen faces you.
    • Use the plastic opening tool to gently pry the top panel with keyboard off of the computer. Work your way around the perimeter and undo the clips holding it down.
    • Don't use a butter knife like in the photo, as this could cause damage to the device.
  3. Dell Inspiron 15 3593 Battery Replacement: 手順 3、 3の画像 1 Dell Inspiron 15 3593 Battery Replacement: 手順 3、 3の画像 2 Dell Inspiron 15 3593 Battery Replacement: 手順 3、 3の画像 3
    • Close the lid and flip the laptop so the backside is facing up.
    • Pull the back panel off to reveal the battery.
  4. Dell Inspiron 15 3593 Battery Replacement: 手順 4、 2の画像 1 Dell Inspiron 15 3593 Battery Replacement: 手順 4、 2の画像 2
    • Disconnect the battery connector from the motherboard.
    • Use the Phillips #0 screwdriver to remove the four (M2x3mm) screws that are keeping the battery in place.
  5. Dell Inspiron 15 3593 Battery Replacement: 手順 5、 1の画像 1
    • Lift the battery out carefully and put the new battery in.
終わりに
Reassemble the computer by following
the above steps in reversed order.
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Abdul Obaid
メンバー登録日: 01/13/22
169 ポイント
1ガイドが承認済み
チーム
York University, Team R-20, Melo-Thaiss Winter 2022 York University, Team R-20, Melo-Thaiss Winter 2022人のメンバー
YORK-MELO-THAISS-W22SRG20
1 メンバー
1のガイドは作成済み
2 件のコメント
not all of the steps
there is somethings missing
aaaa2020 - 返信
So where is the rest of the story?
Jeanette Martinez - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 22
過去 30 日: 88
今までの合計 2,788
