はじめに
In this guide, we will be showing you how to remove and replace the Display Assembly.
必要な工具と部品
Note the antenna cable routing and remove the antenna cables from its routing guides on the computer base.
Note the display cable routing and remove the cable from its routing guides on the computer base.
Align the screw holes on the display hinges with the screw holes on the computer base.
Route the display cable through its routing guides on the computer base.
Route the antenna cables through its routing guides and slide the antenna cables through the slot on the computer base.
もう少しです!
ゴール
